[GRASSLIST:4185] dxf files in 3D
I am anticipating a problem. I have a requested a dataset from a mine geologist which represents the 3D structure of the mine proper from which his proprietary program creates stratigraphic maps. The file contains the information extracted from cores and related samples over decades of drilling and exploration. I need to create depth layers of this data for a project of my own, as opposed to the full 3D images or vertical cross sections he usually works with. I am not certain, but my best chance for acquiring this data may be accepting a 3D dxf file (which imports directly into arcGIS, I am told, but I don't have arcGIS). I have both Grass 5.3 and Grass 5.7 installed on my computer. The 5.3 distribution has a pair of commands, v.in.dxf and v.in.dxf3d, which may serve my purposes. This seems to be missing from 5.7. Is this because the functionality is not yet/never-to-be implemented in 5.7, or is its functionality subsumed by some other command or commands? Will I have to import to 5.3, export to 5.7 and then work with , e.g. grid3D stuff, or can it be done directly in 5.7 ? Are there problems with v.in.dxf3d from 5.3 that I can expect to wrestle with (or perhaps be defeated by)?
Thanks for any advance warning you may be able to give me. I am pressed for time on this project.
v.in.dwg can import also DXF.
Radim
defeated by)?
