[GRASSLIST:421] grass programming
Hello :slight_smile:
I’m getting really desperate with grass …
I want to use its libraries in my C program, but I can’t seem to even understand how to use G_gisinit :frowning:
Is there any manual that you recommend to helo me out?
Help / Rescue would be very much appreciated!!
Thanks :slight_smile:
I'm getting really desperate with grass ...
I want to use its libraries in my C program, but I can't seem to even understand how to use G_gisinit :frowning:
give a look to r.example and v.exaple files (http://grass.itc.it/devel/index.php)
hope it helps...
Max
Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 18
Fax +41 (0)58 666 62 09
Thanks!
That really helped :slight_smile: But I have a lttle problem : I can’t compile it!
Any hints ?
2006/3/27, Massimiliano Cannata <massimiliano.cannata@supsi.ch>:
( http://grass.itc.it/devel/index.php)
hope it helps…
Max
