[GRASSLIST:4217] Generating new linked attribute table after v.overlay
I'm working in 5.7.
Suppose we have two polygons which have attributes linked to an
associated PostGRESQL database.
i.e.
| 1 | 2 |
linking off to a table:
LINK_KEY STATE
1 57
2 59
I now overlay another polygon:
| 10 | 11 |
| 12 | 13 |
| 14 | 15 |
and what I want to do is end up with an associated table linked to the
result of the overlay that looks like this:
LINK_KEY STATE NEW_STATE
10 57 57
11 59 59
12 57 157
13 59 159
14 57 57
15 59 59
I need a few kicks in the right direction (alright, I need to have my
hand held in a major way!) to figure out how to proceed following
v.overlay to ensure that each new polygon resulting from the overlay
has one (and only one!) unique link_key into the new attribute table AND
also how to do the associated query processing based on the STATE (and
other columns) of the original polygons (stored in their original linked
table above) which the overlaid polygon intersects.
Thanks!
Craig
Reclass first input vectors by state ID (v.reclass col=STATE),
then run v.overlay and the table linked to field 1 contains
what you want.
Radim
On Saturday 21 August 2004 00:54, Craig Aumann wrote:
I'm working in 5.7.
i.e.
| 1 | 2 |
LINK_KEY STATE
1 57
2 59
| 10 | 11 |
| 12 | 13 |
| 14 | 15 |
10 57 57
11 59 59
12 57 157
13 59 159
14 57 57
15 59 59
Thanks!
Craig
I'm afraid that's only part of the solution I need. Imagine you have a
trail (represented as a polygon in a separate map layer) running through
different kinds of vegetation types. Each polygon in the vegetation map
links off to an attribute table. I want to overlap the trail with the
vege map so that I know which parts of the trail are in which types of
vegetation and upload this information to the original attribute table
so that each distinct trail-vegetation type polygon links to its own
record in the database. After this, I will then do another v.overlay
(with option NOT) so that the trail will then be represented with
distinct vegetative types (i.e., TRAIL-ASPEN, or TRAIL-PINE) in the
map.
See my code below for precisely what I mean.
## Set the CAT values according to the vegetative classes.
v.reclass input=vegelayer output=vegereclass type=area \
    field=2 col=cover
## Do the overlay.
v.overlay ainput=seismicinterclean binput=vegereclass bfield=1 \
    output=seismicvegetemp operator=and
## Create new CAT values in field 2. These will be used so that each
## vegetative polygon in the overlay links to a single row in the
## table. I add 1000000 to ensure these values are distinct from the
## previous values used to link this table to the original "vegelayer"
## map.
v.category input=vegereclass output=seismicvegetemp2 \
    option=add field=2
v.category input=seismicvegetemp2 output=seismicvegetemp3 \
    option=sum field=2 cat=1000000
## Connect the map to this table.
v.db.connect -o map=seismicvegetemp3 table=play_att \
    field=2 key=link_key \
    driver=pg database="dbname=alpac_netdown,user=caumann"
## Create new rows in the table for each new polygon
## resulting from the overlay.
v.to.db map=seismicvegetemp3 field=2 option=cat type=centroid
NOW, HOW DO I UPLOAD THE CAT VALUES IN FIELD 1 (WHICH CONTAIN THE
VEGE STATE CLASS THIS POLYGON INTERESECTED) TO THE TABLE SO
THAT I CAN EXECUTE QUERIES AND ASSIGN NEW STATE CLASSES USING THOSE
VALUES???
Cheers!
Craig
what you want.
Radim
> I'm working in 5.7.
> i.e.
> | 1 | 2 |
> LINK_KEY STATE
> 1 57
> 2 59
> | 10 | 11 |
> | 12 | 13 |
> | 14 | 15 |
> 10 57 57
> 11 59 59
> 12 57 157
> 13 59 159
> 14 57 57
> 15 59 59
> Thanks!
> Craig
I worry that I haven't got what you exactly want.
You have 3 polygon layers?:
- trail (one or more cats?)
- vegetation
- states
Do you need a table with area_size, vegetation_type, state
in the trail (or outside trail)?
Radim
map.
    field=2 col=cover
## Do the overlay.
## map.
    option=add field=2
VALUES???
Cheers!
Craig
> what you want.
> Radim
> > I'm working in 5.7.
> > i.e.
> > | 1 | 2 |
> > LINK_KEY STATE
> > 1 57
> > 2 59
> > | 10 | 11 |
> > | 12 | 13 |
> > | 14 | 15 |
> > 10 57 57
> > 11 59 59
> > 12 57 157
> > 13 59 159
> > 14 57 57
> > 15 59 59
> > AND also how to do the associated query processing based on the STATE
> > (and other columns) of the original polygons (stored in their original
> > linked table above) which the overlaid polygon intersects.
> > Thanks!
> > Craig
No, its two polygon layers: trails and vegetation. I see I have confused
you by using state class and vegetation interchangeably.
The trail polygon layer comes from buffering line features. The
vegetation layer does not represent trails - it treats the landscape as
vegetation type without any human disturbances. What I want is to end up
with a single new vegetation layer which treats the trail as distinct
vegetation classes which are assigned by me: i.e., TRAIL-PINE,
TRAIL-ASPEN which result from the trail passing through PINE stands or
ASPEN stands. Thus, the final vegetation layer will look like:
| PINE | Trail-Pine | PINE |
where before there just a single "PINE" polygon. Why do I want this?
Because this layer forms the input to a vegetation succession model. It
allows me to say that the successional dynamics of TRAIL-PINE vegetative
polygons are different from the successional dynamics of PINE polygons.
In the code below, I got as far as adding rows into the attribute table
associated with the new TRAIL-VEGETATION layer. The problem is, that
the vegetation class the trail intersected is in Field 1 (i.e., ASPEN,
PINE), and I have linked the attribute table to Field 2 which now
contains distinct LINK_KEYs. How can I copy or get the cat values in
field 1 to the right rows in the attached attribute table via field 2?
Once these values are upload, I can then easily assign new vegetative
state codes (Pine -> Trail-Pine. Aspen -> Trail-Aspen) using SQL
queries.
The following steps (which I know how to do) is to create the new
vegetative layer - which is done by first removing the trail polygons
from the original vegetative layer (NOT overlay) followed by merging in
the TRAIL-VEGETATION polygons using an OR overlay. Given that I have
created distinct LINK_KEYs I should be able to link this final
vegetative layer to the modified attribute table and I'm off to the
races.
I hope this clear things up. Perhaps there is an entirely different way
to do this.
Cheers!
Craig
- vegetation
- states
Radim
> map.
> field=2 col=cover
> ## Do the overlay.
> ## map.
> option=add field=2
> VALUES???
> Cheers!
> Craig
> > what you want.
> > Radim
> > > I'm working in 5.7.
> > > i.e.
> > > | 1 | 2 |
> > > LINK_KEY STATE
> > > 1 57
> > > 2 59
> > > | 10 | 11 |
> > > | 12 | 13 |
> > > | 14 | 15 |
> > > 10 57 57
> > > 11 59 59
> > > 12 57 157
> > > 13 59 159
> > > 14 57 57
> > > 15 59 59
> > > Thanks!
> > > Craig
I think that one v.overlay + SQL should be enough. If you run
v.overlay ainput=seismicinterclean binput=vegereclass \
          output=seismicvegetemp operator=or
you get a table linked to field 1 which has in 'a' column cats from
'seismicinterclean' and in 'b' from 'seismicvegetemp'.
You can for example add a new column
alter table seismicvegetemp add column newtype integer;
and update this column in sql:
update table seismicvegetemp set newtype = b where a is null;
update table seismicvegetemp set newtype = 1001 where a = 1 and b = 1;
update table seismicvegetemp set newtype = 1002 where a = 1 and b = 2;
etc.
then v.reclass col=newtype and v.db.connect to a new table with
all (old+new) vegetation types.
Radim
PS: It is not possible to update a category value of different field
without table. It is however possible to update to one table
a query from another table linked to other field:
v.to.db option=query field= qfield=
queries.
races.
to do this.
Cheers!
Craig
> - vegetation
> - states
> Radim
> > through different kinds of vegetation types. Each polygon in the
> > vegetation map links off to an attribute table. I want to overlap the
> > trail with the vege map so that I know which parts of the trail are in
> > which types of vegetation and upload this information to the original
> > attribute table so that each distinct trail-vegetation type polygon
> > links to its own record in the database. After this, I will then do
> > another v.overlay (with option NOT) so that the trail will then be
> > represented with distinct vegetative types (i.e., TRAIL-ASPEN, or
> > TRAIL-PINE) in the map.
> > field=2 col=cover
> > ## Do the overlay.
> > ## map.
> > option=add field=2
> > VALUES???
> > Cheers!
> > Craig
> > > what you want.
> > > Radim
> > > > I'm working in 5.7.
> > > > i.e.
> > > > | 1 | 2 |
> > > > LINK_KEY STATE
> > > > 1 57
> > > > 2 59
> > > > | 10 | 11 |
> > > > | 12 | 13 |
> > > > | 14 | 15 |
> > > > the result of the overlay that looks like this:
> > > > 10 57 57
> > > > 11 59 59
> > > > 12 57 157
> > > > 13 59 159
> > > > 14 57 57
> > > > 15 59 59
> > > > my hand held in a major way!) to figure out how to proceed
> > > > following v.overlay to ensure that each new polygon resulting from
> > > > the overlay has one (and only one!) unique link_key into the new
> > > > attribute table AND also how to do the associated query processing
> > > > based on the STATE (and other columns) of the original polygons
> > > > (stored in their original linked table above) which the overlaid
> > > > polygon intersects.
> > > > Thanks!
> > > > Craig
Thanks Radim!
By adding new columns to the tables resulting from the v.overlay I think
I was able to get what I wanted.
Cheers!
Craig
