I need to convert about 700 raster datasets into shapefiles - I've written a shell script that does this nicely, except that after processing about 80 of the files through to shapefile I get the following error. The script keeps running, it just fails to write out the shapefiles from then on:
Converting Zosterops_lateralis_7454
CREATING SUPPORT FILES FOR Zosterops_lateralis_7454
25 primitives registered
13 areas built %
5 isles built
Number of nodes : 17
Number of primitives: 25
Number of points : 0
Number of lines : 0
Number of boundaries: 18
Number of centroids : 7
Number of areas : 13
Number of isles : 5
Number of areas without centroid : 6
WARNING: The table <Zosterops_lateralis_7454> is now part of vector map
<Zosterops_lateralis_7454> and may be deleted or overwritten by GRASS modules.
ERROR 4: Failed to open Shapefile `./Shapefiles/Zosterops_lateralis_7454.shp'.Too many open files: /usr/local/grass57/driver/db/
ERROR: Cannot open driver pg
REMOVE [Zosterops_lateralis_7454]
raster
header
category
color MISSING
history
misc
fcell MISSING
g3dcell MISSING
I've appended the shell script - there is a separate wrapper script which just contains a 'while read' loop to pass in the variables that I need to be added in to the attribute table and also a separate SQL template that defines the attribute table structure and then updates the entries using the provided variables. I'm using a home build of GRASS 5.7 (grass57_exp_2004_01_10) on Mac OS X 10.3.5 and using PostgreSQL 7.4.1.
I can just restart GRASS and run batches of 80 or so but it would be great to know where I'm going wrong - I obviously need to release the files in some way.
David
#!/bin/bash
# variables are: infile, smname, smnumber, presence, origin, source tag, sourcename, data_type
# generalize with pg_db, out_dir?
# requires a PostgreSQL dtabase called tmpgrass
if /usr/local/pgsql/bin/psql -l | grep -q "tmpgrass"
then
# get the file basename for export
fname=`basename $1`
echo Converting $fname
v.database driver=pg database=tmpgrass
#check for output folder
if ! ls | grep -q Shapefiles
then
mkdir ./Shapefiles
fi
r.in.arc $1 output=$fname type=CELL
r.to.vect $fname output=$fname feature=area
# get correct attribute table:
# substitute species name into the sql commands into a temporary file
tmpname=tmp.asc2grd.$$.sql
sed -e "s/SMNAME/$2/g" -e "s/SMNUM/$3/g" -e "s/FNAME/$fname/g" -e "s/PRCODE/$4/g" -e "s/ORCODE/$5/g" -e "s/SRCTAG/$6/g" -e "s/SRCNAME/$7/g" -e "s/DATATYPE/$8/g" shpSqlTemplate.sql > $tmpname
# and then execute the sql file
db.execute driver=pg database=tmpgrass input=$tmpname
# reconnect the vector data to the modified table
v.db.connect -o map=$fname driver=pg database=tmpgrass table=$fname key=id
# dump the shapefile version
v.out.ogr -c $fname dsn=./Shapefiles layer=$fname type=area
# delete the temporary raster and sql file
g.remove rast=$fname vect=$fname
rm $tmpname
else
echo "PostgreSQL database tmpgrass does not exist:"
echo " - create using createdb tmpgrass"
fi
