[GRASSLIST:4252] tcltk won't v.support
Grass 5.3. I just did a cvs update.
Redhat Linux 7.3
From tcltk menu Vector->Develop map->create
topology, I get an error in a window that pops up:
couldn't execute "v.support option=build":no such
file or directory
Also, if I try the similar tcltk command v.support
option=edit, I get a terminal type window with:
/gis/local/grass53/tcltkgrass/main/pause:
{v.support: command not found
Finished - press RETURN or ENTER to continue
Note the single "{" character.
These are the only 2 commands I am having trouble with.
Thank you,
John
