Hi, HELP
I have trouble importing an Arcview shapefile.
when i use ,< v,in.shape -1 …>the answer is :
Log file not specified .sending message to ‘standard error’ segment fault.
what is log file? how can i solved this problem and continue?
Ramin Safamanesh
Ramin Safamanesh
Department of Environment Science , UPM
Email : rsafamanesh@hotmail.com Tel : 0060122399448
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
Ramin Safa said:
HELP
when i use ,< v,in.shape -1 ...>the answer is :
Log file not specified .sending message to 'standard error' segment fault.
Ramin Safamanesh
The log file is not the problem. The message just tells you that it will
send all messages to standard error, which is probably just your screen.
However, the problem is the segmentation fault.
Could you tell us what version of GRASS you are using, on what kind of
system (GNU/Linux, UNIX, Cygwin,...) ?
Moritz
hi
Regarding my problem,i will try again.
I’m using system : Linux and Grass5
Ramin
Moritz Lennert mlennert@club.worldonline.be wrote:
Ramin Safa said:
HELP
Ramin Safamanesh
system (GNU/Linux, UNIX, Cygwin,…) ?
Moritz
Ramin Safamanesh
Do you Yahoo!?
hi HELP
thanks for your answer but
i tried again to import but i can't do this.
my file is Arcviw shap ,countur line map,river ,..
GRASS 5.0.0,in red hat system
answer is:
HELPGRASS:~/grassdata/ZARGEH > v.in.shape -l river.shp
out=river
WARNING: Log file not specified. Sending messages to
'standard error'
Segmentation fault
GRASS:~/grassdata/ZARGEH > v.in.shape river.shp out=river
'standard error'
Segmentation fault
i need to continue,but how?
Ramin S.
continue?
> Ramin Safamanesh
you that it will
just your screen.
what kind of
Moritz
Ramin Safamanesh
__________________________________
Do you Yahoo!?
http://sbc.yahoo.com
