[GRASSLIST:4271] r.resamp.rst
hello, in my grass 5.7 distribution (self compilation from 17th of june) i
miss the r.resamp.rst module. i have read some letters dated by the end of
april which says "So today I have experimentally re-enabled compilation of
r.resamp.rst as it may be all right now. ".
how do i get the required module.
thanx, sabine
Hello Sabine
That was for 5.3. r.resamp.rst was added to GRASS 5.7 on 16th July so you need a later version.
If you have 5.3 you can use it from there. (Or use more recent 5.7)
Paul
Hello, I had the same problem. The module r.resamp.rst is not available in the GRASS 5.7.0 sources.
I had to download and compile GRASS 5.3.0 where this module does exist. I don't know if it is included
in the latest CVS version of 5.7, but even so, you need to download 5.3.0 first.
Hope this helps.
Javier Yebrin
-----Original Message-----
From: owner-GRASSLIST@baylor.edu [mailto:owner-GRASSLIST@baylor.edu]On
Behalf Of Sabine Grabner
Sent: Monday, August 30, 2004 10:37 AM
To: GRASS
Subject: [GRASSLIST:4271] r.resamp.rst
of june) i
the end of
compilation of
thanx, sabine
It is, since 16th July 2004.
That is not quite correct---it is the 5.3 CVS HEAD you need (5.3.0 is several months old and not compatible with the latest 5.7 CVS).
Paul
