BTW, thanks for those who helped with my last problem. I couldn't remember
the file name.
New challenge, and some of you will remember trying to help me with this
some months ago. I put it aside then because I had other things to do. No
I am back. I have contour lines I've drawn in Adobe Illustrator. I want to
move them into GRASS as vectors so I can label the elevations and start
using them. This seems to elude me.
I tried converting them into .dxf files, but GRASS can't seem to see it.
I've tried using Textwrangler to change the line breaks to UNIX. I've even
used the program Linebreak for this purpose. I also tried using
Textwrangler to do a hexdump and converted the file to ascii.
One thing I am considering is printing out the contours and trying to use
v.digit to trace them. Can I do this with out a digitizing tablet using an
optical mouse? I may have to get some transparent film and make a target to
tape on it.
remember
the file name.
No
to
What do you mean by this ? What exactly is the procedure you're using and
what are the error messages, if any ?
even
DXF should be ascii, no ?
an
to
tape on it.
Can anyone thing of an easier way of doing it.
I suppose AI can export to raster formats (PNG, JPG, TIFF...), so you
could try that and import the result with r.in.gdal. Then you could either
transform the raster to vector (see http://grass.itc.it/gdp/grass5tutor/HTML/c1452.html), or use the raster as
a backdrop in v.digit and digitize on screen.
the file name.
tape on it.
Any help or advice will be greatly appreciated.
Thanks.
Kurt
I try to avoid serious problems with this by cheating. I create a reference image with a "nice" set of dimensions for importing into a program or script that can give me row-major or other ASCII ordering of numerical values that I can import with an appropriate header. When this is not possible I import it into IDRISI for Windows V 2 and georeference it (really simple in lat/lon under IDRISI if I am careful) and then export an ascii fle I can muck with. For contours I would probably digitize or "scan and scale" if it was hand-drawn or derived from another source.
Has anyonet tried the E00 or Shape file export options in the MapPublisher plugin for Illustrator as a way of getting AI data into GRASS? I find that when working with geo stuff in Illustrator the MapPublisher plugin is an invaluable tool. I just have not tested the export filters yet.
To: Kurt Springs ferret_bard@mac.com cc: GRASSLIST@baylor.edu Subject: [GRASSLIST:443] Re: Getting a file from Adobe Illustrator to GRASS
Kurt Springs wrote: > Hi Folks, > > BTW, thanks for those who helped with my last problem. I couldn't remember > the file name. > > New challenge, and some of you will remember trying to help me with this > some months ago. I put it aside then because I had other things to do. No > I am back. I have contour lines I've drawn in Adobe Illustrator. I want to > move them into GRASS as vectors so I can label the elevations and start > using them. This seems to elude me. > > I tried converting them into .dxf files, but GRASS can't seem to see it. > I've tried using Textwrangler to change the line breaks to UNIX. I've even > used the program Linebreak for this purpose. I also tried using > Textwrangler to do a hexdump and converted the file to ascii. > > One thing I am considering is printing out the contours and trying to use > v.digit to trace them. Can I do this with out a digitizing tablet using an > optical mouse? I may have to get some transparent film and make a target to > tape on it. > > Can anyone thing of an easier way of doing it. > > Any help or advice will be greatly appreciated. > > Thanks. > > Kurt > >
I've just been trying to do the same for some Illustrator EPS files. I couldn't find a GRASS compatible output from Illustrator either. My solution was to parse the postscript code describing polygons in order to get x,y coordinates. Not elegant and it took me a while with my head stuck in the PS language reference so if there is a better way, I'd like to know about it too - I have 600 files to handle! Because my files contained bezier curves, I had to come up with a function to interpolate points along the bezier as well.
Best wishes,
David
On Thursday, June 19, 2003, at 04:57 pm, Kurt Springs wrote:
Hi Folks,
the file name.
tape on it.
