[GRASSLIST:4303] 6s input file
Hi All!
I'd like to try the 6s i.atcorr on a Landsat 7 scene. I managed to get the
module running but I'm having problems with making the txt input file with
parameters. If someone could share such a file I would be gratefull. I have
already found
http://www.ltid.inpe.br/dsr/mauro/6s/ETM4_atmospheric_input.txt but it seems
different than what i.atcorr wants (or I don't understand the i.atcorr
manual).
Markus!
Some time ago you mentioned your i.run.6s script for Landsat 5 on the
mailing list. Would you mind sending it to me or putting it somewhere for
download?
Best
Maciek
On Sat, Sep 04, 2004 at 10:18:07PM +0200, Maciek Sieczka wrote:
Hi All!
already found
manual).
Markus!
download?
You can grab it here:
http://mpa.itc.it/markus/grass53/i.run.6s_script.tar.gz
(360k, including 6S for linux from some years ago)
I didn't test it recently but used it successfully in 1999.
> Hi All!
> the module running but
that is only partly true actually :frowning:
it compiled fine but it doesn't work
I'm always getting:
* atmospheric correction activated
Percent complete: Segmentation fault
I built it twice - against the Grass 5.3 CVS, own build, and the 5.03,
precompiled
each time the same result
could somebody help me getting the i.atcorr to work please?
in case my config.log and make.log are attached
I'm using a Mandrake 9.2 if it matters
Maciek
File attachment: atcorr_logs.zip
The file attached to this email was removed
because the file name is not allowed.
