[GRASSLIST:4318] grass maps via mapserver
hello
I tried to get grass maps via mapserver. But I couldn't
and no error is received. Just map is not seen
what might be possible problems ?
regards
Ahmet Temiz
______________________________________
Inflex - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
Are you on Linux or Windows? Try
   gdalinfo --formats
to make sure gdal supports GRASS
put a .grassrc5 into the DocumentRoot location as defined in the
httpd.conf file.
(e.g. /usr/local/apache2/htdocs or /var/www/html on Mandrake 9.0)
Also, the LAYER object DATA
element needs to reference the raster from the cellhd directory (e.g.
/data/grass/location/mapset/cellhd/mymap).
For me, the full path did not work, but when I put the .grassrc file
in /var/www/html I did not need to specify a full path.
Richard Greenwood
richard.greenwood@gmail.com
www.greenwoodmap.com
On Tue, 07 Sep 2004 16:37:26 +0300, temiz <temiz@deprem.gov.tr> wrote:
hello
regards
Ahmet Temiz
