[GRASSLIST:4353] s.surf.rst in a lat/long
the "slope" output of s.surf.rst in my wgs84 lat/long projection is wrong -
it's value range is min=89.721184 and max=89.999451 and the raster looks
rubbish
a similar approach in a tmerc projection gave a good result
my fault or some bug?
below is my "procedure" listed in detail
GRASS:~ > g.region -p
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 50:45:57N
south: 50:42:12N
west: 15:40:54E
east: 15:46:57E
nsres: 0:00:03
ewres: 0:00:03
rows: 75
cols: 121
GRASS:~ > r.info N50E015.meters_filled
| Layer: N50E015.meters_filled Date: Sun Sep 5 19:34:34 2004
| Mapset: dem Login of Creator: ziutek
| DataBase: /home/grassdata
| Title: ( N50E015.meters_filled )
| Type of Map: raster Number of Categories: 1594
| Data Type: FCELL
| Rows: 1201
| Columns: 1201
| Total Cells: 1442401
| Projection: Latitude-Longitude (zone 0)
| N: 51:00:01.5N S: 49:59:58.5N Res: 0:00:03
| E: 16:00:01.5E W: 14:59:58.5E Res: 0:00:03
| Range of data: min = 178.000000 max = 1594.000000
| Data Source:
| Data Description:
| generated by r.patch
GRASS:~ > r.to.sites -a input=N50E015.meters_filled output=dem_sites
GRASS:~ > s.info dem_sites
NDIM=2, RTYPE = -1, NSTR=0, NDEC=1
Total sites read: 9075
Total sites outside region: 0
dem_sites read.
SITES FILENAME: dem_sites
Header Information:
        name dem_sites
        description r.to.sites -a input=N50E015.meters_filled
output=dem_sites label='No Label'
        format ||%
        labels Easting|Northing|%No Label
Number of DIMENSIONS: 2
                 - - MIN - - - - MAX - -
        dim 1 15.682083 15.782083 Easting
        dim 2 50.703750 50.765417 Northing
Type of CATEGORY information: NO CATEGORY
Number of DOUBLE attributes: 1
        dbl 1 682 1594 No Label
Number of STRING attributes: 0
TOTAL SITES COUNTED: 9075
GRASS:~ > s.surf.rst input=dem_sites elev=dem_s.surf.rst
slope=dem_s.surf.rst_slp aspect=dem_s.surf.rst_asp
The number of points in sites file is 9075
The number of points outside of region 0
The number of points being used (after reduction) is 9075
Processing all selected output files
will require 84888 bytes of disk space for temp files
100%
Percent complete: history initiated
GRASS:~ > r.info -r dem_s.surf.rst
min=682.395142
max=1593.271240
GRASS:~ > r.info -r dem_s.surf.rst_asp
min=0.549078
max=360.000000
GRASS:~ > r.info -r dem_s.surf.rst_slp
min=89.721184
max=89.999451
I forgot to mention that I run into this on a Grass 5.3 CVS
grass53_exp_2004_08_21 built from source
Respected sir
i am donig work with indictrans team on grass5.0.3 and now i am able to
connect vector maps wih data base tables and also can update the values
of data base through maps .now i want to work on web grass and for that
i found grasslink site but
While trying to retrieve the URL:
http://www.regis.berkeley.edu/grasslinks/
The following error was encountered:
    Unable to determine IP address from host name for
The dnsserver returned:
    Name Error: The domain name does not exist.
please tell me that this site exist or not and if any other option is
able to work on web grass then help me .
thanks
indictrans team
try: http://ippc2.orst.edu/glinks/
or other "Web modules" on http://grass.ibiblio.org/grass_addons.html
Hamish
