[GRASSLIST:4384] create a network
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I have an area polygonal vector and I'd like to create a network between its
elemnts. It is possible to create a network where the linking lines are the
minimum distances between the boundaries of the nodes?
Thanks to all the list
Leonardo Lami
lami@faunalia.it www.faunalia.it
Via Colombo 3 - 51010 Massa e Cozzile (PT), Italy Tel: (+39)349-1310164
GPG key @: hkp://wwwkeys.pgp.net http://www.pgp.net/wwwkeys.html
https://www.biglumber.com
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFBT+4U92hCyP73w7ARAqynAJ4wc/Ih96kQ/CzvNa2ykC8UtoaBwwCgkDii
RQCs6v4nf2G3qHa0WUcEWDs=
=KDLU
-----END PGP SIGNATURE-----
On Tuesday 21 September 2004 11:02, Leonardo Lami wrote:
its elemnts. It is possible to create a network where the linking lines are
the minimum distances between the boundaries of the nodes?
Not sure if it is what you want, I have a module doing this
(the red line generated from green+blue):
http://mpa.itc.it/radim/g51/v.area.path.png
It is not finished, I can send it to you, but without any additional support.
Radim
> Hi,
Radim
Just for the record:
v.voronoi
Description:
Create a Delaunay triangulation from an input vector of points or centroids.
now in 5.7 thanks to Radim.
