[GRASSLIST:4395] starting grass from shell for a batch job
dear listers,
I would like to apply a grass script to many locations and mapsets from a bash shell ; I tryed several ways of piping the script with the grass command such as :
#!/bin/sh
./grass_script | grass /data_directory/location/mapset
exit 0
But I get an error message for each grass command used within the grass_script, even though I can see grass starting and closing fine …
any ideas ? thank you very much,
eric pante (ericpante@hotmail.com)
from a bash shell
Switching mapsets with a GRASS session is easy. Locations are not as
easy. Maybe "safe" is a better word than "easy".
5.7: use g.mapset (not g.mapsets with an "s", grumble)
5.3: use the attached script for new mapsets, otherwise g.gisenv.
This is use at your own risk stuff.
Hamish
(attachments)
g.nm (1.1 KB)
