When exporting areas (with labeled centroids) from 5.7, then linking the
shape file back in with v.external, I see that what were holes in the
area are now new areas with their own centroids.
What's the correct way to export areas with holes into a shape file,
while keeping the holes as holes?
currently using:
v.out.ogr dsn=. type=area in=some_area layer=some_area
currently using:
> [5.7]
> the shape file back in with v.external, I see that what were holes
> in the area are now new areas with their own centroids.
> currently using:
Radim:
-c
Yes, that works. Thanks.
Next issue:
after linking the resultant shape file back in with v.external, the
categories are labeled starting with 0 instead of 1. This caught me out
when doing 'd.vect cat=1-1000' and the first area was missing. (the
linked table has a "cat" column which has the original (correct) cat
number but is unused.
Is this a bug or a feature?
out when doing 'd.vect cat=1-1000' and the first area was missing.
(the linked table has a "cat" column which has the original (correct)
cat number but is unused.
This is the "id" column created by v.out.ogr.
perhaps v.external could get category info from the "cat" column if one
exists? shrug.
