[GRASSLIST:447] raster example
Hello :slight_smile:
I’ve the raster example from (http://grass.itc.it/devel/index.php) but I’m having trouble compiling it
I run make but I get
Makefile:10: …/…/include/Make/Module.make: No such file or directory
make: *** No rule to make target `…/…/include/Make/Module.make’. Stop.
So what must I do to get it to work ?
Thanks anyway :slight_smile:
I've the raster example from (http://grass.itc.it/devel/index.php) but I'm
Makefile:10: ../../include/Make/Module.make: No such file or directory
make: *** No rule to make target `../../include/Make/Module.make'. Stop.
Since it seems to be confusing, I have fixed the
relative link in the Makefile.
Just download it again (only the Makefile) and it will work,
or fix the first line after the comment in the Makefile which
you have already downloaded.
cheers
Hello
Sorry to bother you again, I promise its the last one (today, anyway) :slight_smile:
I can’t seem to find Module.make on my file system.
I have ubuntu, somewhat similar to debian.
seabiscuit@ubuntu:/usr/lib/grass/include$ ls
bdlg_bm.h devlib.h geom.h ibtree.h lock.h raster.h spawn.h
bitmap.h dgl gisdefs.h icon_bm.h monitors.h readsites.h sqlp.h
blas.h dgl.h gis.h icon.h ogsf_proto.h region_bm.h std_incs.h
btree.h D.h glocale.h imagedefs.h ortholib.h rowio.h symbol.h
CC.h dig_atts.h gmath.h imagery.h Paintlib.h rtree transform.h
cdhc.h display.h gproj_api.h keyframe.h patterns.h rtree.h vask.h
codes.h dlg_bm.h gprojects.h kftypes.h pbmplus.h search.h vbuildlib.h
colors.h dlg.h graph.h label_bm.h P_datetime.h segment.h vect
config.h edit.h grass la.h portable.h shapefil.h Vect.h
dataquad.h form.h gstypes.h lapack.h proto_dbmi.h shhopt.h version.h
datetime.h G3d.h gsurf.h libtrans.h P_site.h site.h V_.h
dbmi.h geo.h help.h linkm.h qtree.h sitelib.h winname.h
I used synaptic to install grass.
Maybe I’ve dne something wrong ?
Thanks
2006/3/28, Markus Neteler <neteler@itc.it>:
cheers
---------- Forwarded message ----------
Date: 28/03/2006 15:50
Subject: Re: [GRASSLIST:448] Re: raster example
To: grasslist@baylor.edu
Hello
GRASS 6.0.1 (spearfish60):~/Desktop/raster/r.example > make
Makefile:10: …/…/…/include/Make/Module.make: No such file or directory
make: *** No rule to make target `…/…/…/include/Make/Module.make’. Stop.
Thanks
I’ve the raster example from ( http://grass.itc.it/devel/index.php) but I’m
cheers
