[GRASSLIST:4472] Bus Error in ps.map on Mac OS 10.3
I am getting a bus error in ps.map when I try to print the colortable. Although it doesn't give an error, ps.map does not print the vector maps either. This is on Mac OS X 10.3.5
Brian
colortable.
This is two errors? 5.3 or 5.7? can you reproduce it using the
Spearfish data set and file a bug report along with the exact input
commands and terminal output?
http://grass.ibiblio.org/bugtracking/bugreport.html
http://grass.ibiblio.org/data.html
Hamish
_______________________________
Do you Yahoo!?
Declare Yourself - Register online to vote today!
http://vote.yahoo.com
This is in Grass 5.7.
The first error was mine. The colortable was not being printed because it did not exist. I went in and edited the cats file manually and the colortable now prints. I used to do this with r.support, but this is gone.
Nevertheless, it does do something a bit odd. I ask for three columns using cols 3 (there are six categories.) It prints three on the first row, two on the second and the last on a third. It would be nice to have two rows of three.
It still does not print the vector map. I am new to playing with vlines and vareas, so I still suspect that the problem is in my ps.map input file.
Brian
colortable.
Hamish
Do you Yahoo!?
I am still having a problem with colortable in ps.map. When I put in the columns command (ie cols 3) it always prints one less column on the second to last row and a single column on the last row. For example,
colortable y
  raster Regions
  font Helvetica
  fontsize 36
  color black
  cols 7
  width 36
  nodata n
end
This prints six columns on the first row and one on the second. I have tried using cols 8, and increasing the width and it still does the same thing.
Brian
