[GRASSLIST:4474] Re: DEMPSTER-SHAFER modelling
I wrote those modules a little while ago.
They work fine with GRASS 5.3 and can,
in principle be used for any sort of predictive model.
My plan is to adapt the code for GRASS 5.7 and commit
it to the CVS version.
I have no homepage or any place to distribute the current
version, but will email it to you if you want it.
Unfortunately, I am in Egypt right now and have no
access to my progs.
You will have to wait until I get back home at the
start of November.
You will also have to compile the modules yourself and
add them to your GRASS 5.3 installation.
Benjamin
----- Originalnachricht -----
Von: Chavoux Luyt <educluyt@sun.ac.za>
Datum: Mittwoch, 6. Oktober 2004 5:13 pm
Betreff: [GRASSLIST:4473] Re: DEMPSTER-SHAFER modelling
Hi
Some time ago I read about a GRASS module for archeological
modelling
using the DEMPSTER-SHAFER method. It had a link to an ESRI webpage
describing the method, but used in habitat analysis on ArcView. I
would
like to know if the GRASS module can also be used for this purpose
(predicting occurence of animals from habitat factors) instead of
for
archeology. Unfortunately I can't remember the author of the
module (I
didn't at the time think it would be usefull for my puposes).
Any help will be appreciated.
Chavoux Luyt
