for MYCAT in `echo "select distinct avicat from allpoly_att"|db.select
-c`; do
echo $MYCAT
AGE=`echo "select age from play_att where link_key = $MYCAT" |
db.select -c`
COVER=`echo "select cover from play_att where link_key = $MYCAT" |
db.select -c`
echo "update allpoly_att set age = $AGE where avicat = $MYCAT" |
db.execute
echo "update allpoly_att set cover = $COVER where avicat = $MYCAT" |
db.execute
done
Right now, it is doing about 2 updates per second - which is too slow!
Is the slowness caused by piping it through db.execute?
-c`; do
echo $MYCAT
db.select -c`
db.select -c`
db.execute
$MYCAT" |
db.execute
done
slow!
Other suggestions for speeding this up?
you might scatter in the "date" unix command in to show a timestamp or
use the "time" command ('time db.execute ...') to profile which command
is the slow link.
Hamish
_______________________________
Do you Yahoo!?
Declare Yourself - Register online to vote today! http://vote.yahoo.com
On Thursday 07 October 2004 00:03, Craig Aumann wrote:
The code is very simple:
-c`; do
echo $MYCAT
db.select -c`
db.select -c`
db.execute
db.execute
done
