Hi everyone!
I am trying to start grass mapserver demo, with spearfish location for some time and i realy don't know what else to do.
I am using :
linux suse 9.0 with apache2 web serever, PHP 4.3.9 configured as CGI,
libgrass5-1.0.0,
gdal 1.2.3 configured with-libgrass
mapserver -4.2.3 configured wit folowing arguments:
./configure --with-eppl --with-threads --with-proj --with-gdal=/usr/local/bin/gdal-config --with-ogr=/usr/local/bin/gdal-config --with-php=/root/php-4.3.9 --with-gd=/usr/local --with-freetype=/usr/bin --with-pdf
I have installed grass57 and i copied .grassrc57 i htdocs directory, but I still recive message
msDrawMap(): Image handling error. Failed to draw layer named 'soils'.
msDrawRaster(): Image handling error. Unrecognized or unsupported image format
drawEPP(): Image handling error. /srv/www/grassdata/spearfish/PERMANENT/cellhd/soils is not an EPPL file.
when I try to display soils layer directly from the grass location.
All other layers are displaying corectly.
I get the folowing outputs for the tests
#./mapserv -v
MapServer version 4.2.3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
# ldd /usr/local/lib/libgdal.so
libodbc.so.1 => /usr/local/lib/libodbc.so.1 (0x4032c000)
libxerces-c1_6_0.so => /usr/local/lib/libxerces-c1_6_0.so (0x4038a000)
libpthread.so.0 => /lib/i686/libpthread.so.0 (0x405b7000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40609000)
libpng.so.3 => /usr/lib/libpng.so.3 (0x40629000)
libgrass5.so.0 => /usr/local/lib/libgrass5.so.0 (0x40657000)
libz.so.1 => /lib/libz.so.1 (0x406dd000)
libdl.so.2 => /lib/libdl.so.2 (0x406ec000)
libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x406ef000)
libm.so.6 => /lib/i686/libm.so.6 (0x407b0000)
libc.so.6 => /lib/i686/libc.so.6 (0x407d3000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x40906000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
libnsl.so.1 => /lib/libnsl.so.1 (0x4090e000)
# /usr/local/bin/gdal-config --formats
gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 xpm sdts raw dted mem jdem envisat elas fit vrt usgsdem l1b nitf bmp pcidsk bsb gif jpeg png grass
What else could go wrong??
best regards
Ljiljana Bodrozic
On Wed, 13 Oct 2004 11:03:16 +0200, Ljiljana <ljiljana@fesb.hr> wrote:
Hi everyone!
I am using :
libgrass5-1.0.0,
--with-pdf
format
#./mapserv -v
INPUT=SHAPEFILE
(0x4038a000)
best regards
Ljiljana Bodrozic
Try renaming the .grassrc57 in htdocs to just ".grassrc5" or ".grassrc"
Richard Greenwood
richard.greenwood@gmail.com
www.greenwoodmap.com
Thanx!!!
I have already tried that, with all other combinations (.grassrc in www , grassrc with all permisions in htdocs, , grassrc in database folder...) . I dont know what is the difference now, but now it works.
Now I will be afraid to change anything
Thank you once again
Ljiljana Bodrozic
----- Original Message ----- From: "Richard Greenwood" <richard.greenwood@gmail.com>
To: "Ljiljana" <ljiljana@fesb.hr>
Cc: <grasslist@baylor.edu>
Sent: Wednesday, October 13, 2004 3:09 PM
Subject: [GRASSLIST:4520] Re: grass and Mapserver
Hi everyone!
I am using :
libgrass5-1.0.0,
--with-pdf
format
#./mapserv -v
INPUT=SHAPEFILE
(0x4038a000)
best regards
Ljiljana Bodrozic
Richard Greenwood
On Thu, Oct 14, 2004 at 08:36:44AM +0200, Ljiljana wrote:
Thanx!!!
As you are using 'libgrass', the name must be .grassrc5 (as suggested by
Richard).
A 'grep' in libgrass source code reports:
./gis/gisinit2.c: * In this case put .grassrc5 into the DOCUMENT_ROOT directory
./gis/gisinit2.c: sprintf( gisrc, "GISRC=%s/.grassrc5", getenv("DOCUMENT_ROOT") );
./gis/gisinit2.c: sprintf( gisrc, "GISRC=%s/.grassrc5", getenv("HOME") );
I have now unpacked the README:
http://grass.itc.it/spearfish/README
".grassrc5: contains LOCATION and MAPSET and DATABASE definition for
SPEARFISH
- put in /usr/local/httpd/htdocs/
Good luck
>>Hi everyone!
>>I am using :
>>libgrass5-1.0.0,
>>--with-pdf
>>I
>>format
>>#./mapserv -v
>>INPUT=SHAPEFILE
>>(0x4038a000)
>>jdem
>>best regards
>>Ljiljana Bodrozic
>Richard Greenwood
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
So, if I understood it right, grass aplication does not have anything to do with mapserver. Mapserver comunicates with grass-gis layars only using libgrass.
I have read something about changes in gdal-1.2.3 ( I had to configure it --with-libgrass, not --with-grass, as later versions).
Can Mapserver with gdal-1.2.3.work with grass without libgrass (somehow colecting the libraries for displaying grass directly from the grass) ?
Best regards
Ljiljana Bodrozic
----- Original Message ----- From: "Markus Neteler" <neteler@itc.it>
Sent: Friday, October 15, 2004 9:24 AM
Subject: Re: [GRASSLIST:4530] Re: grass and Mapserver
Thanx!!!
Richard).
SPEARFISH
Good luck
