does anyoen know where I can find a descrption of the eps format, so I could
write a program to make an eps output?
I'm learning C and I think this could be a good exercise.
thanks all
Carlos Henrique Grohmann - Guano
Geologist M.Sc - PhD Student at IGc-USP - Brazil
Linux User #89721 - guano at usp dot br -
If you want to "produce" your own graphics, also take a look on the GD Library http://www.boutell.com/gd/
HTH,
Eve
Carlos Henrique Grohmann wrote:
Hello all,
thanks all
The standard reference for PostScript is the "Red Book", formally known as
"PostScript Language Reference" in its 3rd edition from Adobe. EPS stands
for Encapsalated PostScript and simply has a bounding coordinate box
specified. PDF and PS/ESP are similar except PDF lacks the programming
elements (and therefor cannot carry malicious code to other machines). PDF
also supports features like transparency. Amazon.com lists the book for
$34
(http://www.amazon.com/exec/obidos/tg/detail/-/0201379228/qid=1097682963/sr=8-2/ref=pd_csp_2/104-6003528-2503115?v=glance&s=books&n=507846).
The publisher's website is:
(http://www.awprofessional.com/title/0201379228). When writing your
program I suggest including support for turning Grass themes/datasets into
EPS layers.
Best of luck,
_Nathaniel Vaughn Kelso
Research Cartographer
National Geographic Maps
1145 - 17th Street NW
Washington DC 20036
could
thanks all
I don't know if this will help, but there is a program called ps2eps that is already out there. It converts postscript into encapsulated post script by putting a bounding box around the original file. You can find it here
On Oct 13, 2004, at 8:35 AM, Carlos Henrique Grohmann wrote:
Hello all,
thanks all
specified.
There's more to it than that. An EPS file is a PostScript file which
conforms to the Document Structuring Conventions (DSC), and includes a
preview bitmap. The DSC cover not only the bounding box, but also
things such as page numbers, resources (e.g. raster images) etc.
EPS is "Encapsulated PostScript", and it's essentially just PostScript
which conforms to certain conventions. Note that PostScript isn't a
data format but a full programming language.
Not really. Writing a C program to generate PostScript would teach you
more about programming in PostScript than programming in C.
