Hello
I’ve installed
[libgrass-dev](http://packages.debian.org/unstable/libdevel/libgrass-dev)
using synaptic on ubuntu.
But, even as root, don't have the directory
/usr/lib/grass/include/Make
so I don't have the
Module.make file
root@ubuntu:/usr/lib/grass/include# ls
CC.h cdhc.h dlg.h graph.h la.h proto_dbmi.h site.h
D.h codes.h dlg_bm.h grass label_bm.h
qtree.h sitelib.h
G3d.h colors.h edit.h gstypes.h lapack.h raster.h spawn.h
P_datetime.h config.h form.h gsurf.h libtrans.h readsites.h sqlp.h
P_site.h
dataquad.h geo.h help.h linkm.h region_bm.h std_incs.h
Paintlib.h datetime.h geom.h ibtree.h lock.h rowio.h symbol.h
V_.h dbmi.h gis.h icon.h
monitors.h rtree transform.h
Vect.h devlib.h gisdefs.h icon_bm.h ogsf_proto.h rtree.h vask.h
bdlg_bm.h dgl glocale.h imagedefs.h ortholib.h search.h vbuildlib.h
bitmap.h dgl.h gmath.h imagery.h patterns.h segment.h vect
blas.h dig_atts.h gproj_api.h keyframe.h pbmplus.h shapefil.h version.h
btree.h display.h gprojects.h
kftypes.h portable.h shhopt.h winname.h
Can anyone help me with this problem ? Please ?
Ana Soares wrote:
Hello
I've installed
libgrass-dev <http://packages.debian.org/unstable/libdevel/libgrass-dev>
so I don't have the
Module.make file
qtree.h sitelib.h
P_site.h
Apparently you want to compile GRASS commands without having the GRASS
source code.
This wasn't possible so far, but there is a new "GRASS Extension
Manager" in the works
which should probably do what you want:
http://www.uni-kiel.de/ufg/ufg_BerDucke.htm
Maybe you give it a try and report back?
Hello
Thanks for answering
I’ve succeeded to compile the raster example with the following commands :
gcc -c -I /usr/lib/grass/include main.c
gcc -o main -L/usr/lb/grass/lib main.o -lgrass_lib -lm
But I had to remove '’ in lines such as
G_fatal_error((“Cannot open cell file [%s]”), name);
Otherwise I would still get the PACKAGE error.
And it works! (I have no idea why…
Thanks for your help ! It was difficult at first for me to understand GRASS programming, but now I think I’m getting the hang of it!
2006/3/30, Markus Neteler <neteler@itc.it>:
Ana Soares wrote:
Hello
I’ve installed
libgrass-dev <http://packages.debian.org/unstable/libdevel/libgrass-dev >
But, even as root, don’t have the directory
so I don’t have the
Module.make file
qtree.h sitelib.h
P_site.h
source code.
This wasn’t possible so far, but there is a new “GRASS Extension
Manager” in the works
