Hello,
I have downloaded the Precompiled Binaries winGRASS 5.7 from this
site(http://grass.baylor.edu//grass57/binary/mswindows_cygwin/) and
installed them following the instruction from this
site(http://grass.baylor.edu//grass57/binary/mswindows_cygwin/cygwin_grass.html).
After the installation was completed ,I wanted to try out the sample
data set named "3D weather
situation"(http://grass.baylor.edu//grid3d/grass5grid3d_sample.tar.gz)
in this page(http://grass.baylor.edu//grid3d/index.html#sample). But
when I used the "r3.mkdspf" command , bash output "command no found"
and I cannot find r3.mkdspf and r3.showdspf files anywhere.
Is there anyone can do me a favor?
On Fri, Oct 29, 2004 at 10:51:06AM +0800, amos gong wrote:
Hello,
Note:
We'll replace this data set as soon as possible with a better one.
The "3D weather situation" is not in sync with the current G3D status.
But when I used the "r3.mkdspf" command , bash output "command no found"
We'll have to find a volunteer to build a fresh winGRASS 5.7 package.
> Hello,
> in this page(http://grass.baylor.edu//grid3d/index.html#sample).Note:
The "3D weather situation" is not in sync with the current G3D status.> But when I used the "r3.mkdspf" command , bash output "command no found"
> Is there anyone can do me a favor?We'll have to find a volunteer to build a fresh winGRASS 5.7 package.
I'm going to build a package.
Coming soon!
Huidae Cho
OK, I've built both 5.3 and 5.7 without fftw support because grass
requires the old version of fftw. By the way, can I put all the
binaries of the modules including r.terraflow in a binary
distribution?
Huidae Cho
On Fri, 29 Oct 2004 10:23:24 -0500, Huidae Cho <grass4u@gmail.com> wrote:
> > Hello,
> Note:
Coming soon!
Huidae Cho> Markus
