I am running Mac OS X (10.2.8) and have compiled grass 5.7 (cvs). However, when I run v.in.ogr, I get this error
GRASS 5.7.cvs:~/gisdata/grass_x/93f/93f037 > v.in.ogr dsn=tctr_037 \
layer=LAB,ARC type=line out=tctr_037
A datum name nad83 (North_American_Datum_1983) was specified without transformation parameters.
WARNING: Non-interactive mode: the GRASS default for nad83 is
towgs84=0.000,0.000,0.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
WARNING: The vector 'tctr_037' already exists and will be overwritten.
dbmi: db_open_database() not implemented
WARNING: Cannot open database
'/Users/dave/gisdata/grass/trim-utm10/dave/dbf'
'/Users/dave/gisdata/grass/trim-utm10/dave/dbf' by driver 'dbf'
WARNING: Cannot get info if table 'tctr_037_1' linked to vector exists.
ERROR: Cannot delete existing vector tctr_037
Is this a GDAL problem?
Dave
We have the same problem on Cygwin in terms of the db error. You may
want to configure with --disable-shared.
./configure --disable-shared
make
Hope this helps.
Huidae Cho
On Sun, 07 Nov 2004 19:08:13 -0800, David Mahoney <mahoneyd@unbc.ca> wrote:
Dave
Thanks, that fixed it. Does anyone know why shared libraries no longer
work? They were fine before I reinstalled Mac OS (and updated the grass
sources from CVS).
Dave
make
Hope this helps.
Huidae Cho
wrote:
'dbf'
Dave
I'm on Mac OS X here and have no problems with shared libs. Tho I have 10.3.6. But I don't think that should make that big a difference as long as you have the GCC 3.3 Dev tools for 10.2.8.
I briefly had that error with dbmi when the developers were messing around with the linker options a while back, and it has changed again recently. For this error, it's a combination of link options that can cause the dbmi functions to not build right. It's not a GDAL problem.
Take a look at my GRASS build instructions for Mac OS X:
http://webpages.charter.net/kyngchaos/macosx/index.html
sources from CVS).
Dave
make
Hope this helps.
Huidae Cho
wrote:
'dbf'
Dave
William Kyngesburye <kyngchaos@charter.net>
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
I fixed it and shared libraries work on Cygwin, so could you test this
on MacOS? Db drivers with shared libraries should work; you don't need
--disable-shared flag.
Huidae Cho
On Mon, 8 Nov 2004 21:25:20 -0800 (PST), mahoneyd@unbc.ca
sources from CVS).
Dave
> Hi,
> make
> Hope this helps.
> Huidae Cho
> wrote:
>> Hi,
>> 'dbf'
>> Thanks,
>> Dave
New code lives in grass51 CVS HEAD.
On Thu, 11 Nov 2004 11:16:07 -0600, Huidae Cho <grass4u@gmail.com> wrote:
Huidae Cho
> sources from CVS).
> Dave
> > Hi,
> > make
> > Hope this helps.
> > Huidae Cho
> > wrote:
> >> Hi,
> >> 'dbf'
> >> Thanks,
> >> Dave
