and from lapack-3.0 compilation:
drwxr-xr-x root/root usr/
drwxr-xr-x root/root usr/lib/
-rw-r--r-- root/root usr/lib/lapack_linux.a
lrwxrwxrwx root/root usr/lib/liblapack.a -> lapack_linux.a
those libraries are obviously perfect and they are succesfully utilized
from programs like octave-2.1.59 and R-2.0.0 .
This is my grass-5.7.0 configure :
./configure --prefix=$PKG/opt --exec-prefix=$PKG/opt \
--enable-64bit-vis=no --with-cxx --with-fftw --with-proj \
--with-motif --with-blas --with-lapack \
--with-mysql=no --with-odbc=no --disable-nls \
--with-opendwg --with-opendwg-includes=$ODA --with-opendwg-libs=$ODA
I succesfully compile grass but there is no support for blas/lapack.
First, the BLAS library has to be called libblas.* (i.e. it can be
linked using -lblas).
Second, I'm not sure whether anything can actually use BLAS/LAPACK at
present. If those libraries are enabled, some additional functions are
available in the gmath library. However, I'm not sure whether anything
actually uses those functions.
On Tue, 9 Nov 2004 15:59:17 +0000
glynn@gclements.plus.com wrote:
_omissis__
