[GRASSLIST:4770] r.in.tiff: problems
Thanks to those who helped with my previous query- I'm now getting somewhere!
Next I'm trying to bring in some SRTM topographic data. I've used MacDEM to merge 4 degree squares and exported these as a tiff with world file. Using r.in.tiff, I get three bands (.r, .g, .b). However band .r displays as null values, .g and .b display as greyscale.
Any ideas what's going on?
Lawrence
Probably because MacDEM saves a color TIFF - I think the defaults have a blueish color for either the zero elevs or nulls. (it's been a while since I used MacDEM) Even if you could get it to save a grayscale tiff, you'd still have to deal with the nulls somehow.
A better way to bring in SRTMs into GRASS is directly, using r.in.gdal. Then use GRASS to patch them together. There's been a few queries about it on the list recently - check the archives. Maybe when I have time to figure out the new wiki I'll add something there.
On Nov 11, 2004, at 4:25 AM, lawrence moran wrote:
Lawrence
William Kyngesburye <williamk@mappingspecialists.com>
Mapping Specialists <http://www.mappingspecialists.com>
Don't Panic
Try Markus's r.in.srtm scripts, they work quite well.
http://mpa.itc.it/rs/srtm/index.html
Then patch together with r.patch.
Hamish
Seems a bit messy, going thru tiff, then fixing INT16 problems. I prefer to go direct from the SRTM file.
I've been using my own clunky method for generating the hdr file, but Markus' would work if you just remove the gdal_translate step in srtm_generate_hdr.sh. Then just use r.in.gdal. It correctly takes care of the BIL cell center -> GRASS cell corner translation (you get a raster who's bounds are 1.5 seconds outside the degree square). You could simplify it all by merging the generate hdr into r.in.srtm.
Hamish
William Kyngesburye <kyngchaos@charter.net>
http://webpages.charter.net/kyngchaos/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
Here you can grab the scripts:
... yes, and then it should go into 5.7 ...
Please send the merged script if you find the time.
Lawrence,
I see others have offered more comprehensive solutions. However, this might
help you and others with r.in.tiff.
Based on my experience with the module, r.in.tiff assumes that you have a
RGB color file and tries to parse it into red, green, and blue channels. In
your case, you have a single channel elevation file. Both your green (*.g)
and blue (*.b) bands are probably identical (subtract one from the other
using r.mapcalculator to check). I'm not sure what is going on with the red
channel (*.r). It might or might not be significant.
In other words, I *think* that either of your green or blue channels are
your imported DEM. You can do a few spot checks using d.what.raster to
verify this.
Michael Barton
On 11/11/04 3:25 AM, "lawrence moran" <L.J.Moran@newcastle.ac.uk> wrote:
Lawrence
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
