H_B
1
I am having trouble with the environment variables.
They aren't set by default any more. If you want to use them,
g.gisenv will list current GRASS state (from the ~/.grassrc5 file)
and
eval `g.gisenv` will "activate" the variables listed in g.gisenv.
so
eval `g.gisenv`
cd $GISDBASE/$LOCATION_NAME
should work.
set or echo $[tab][tab] will list currently available enviro vars
Hamish
For my fellow Luddites still running tcsh instead of bash, "eval `g.gisenv`" doesn't work. But placing these lines into .grass.cshrc
eval `g.gisenv | awk -F= '{print "setenv " $1 " " $2}'`
alias cdmap 'cd $GISDBASE/$LOCATION_NAME/$MAPSET'
alias cdloc 'cd $GISDBASE/$LOCATION_NAME'
does the trick quite nicely. Thanks Erin for the question, and 2 unnamed respondents for the answers and nudge!
H
