Ian, thanks for help us.
We try to do this, using in ‘your_map’ our imported map LagesBairrosdxf.0.
But we get a follow message: “error while loading shared libraries: libproj.so.0: cannot open shared object file:No such file or directory.”
We try download this library, but the file is empty!!!
What can we do?
grupoSIG - UNIPLAC, Lages - Brazil.
--------- Mensagem Original --------
De: “Ian MacMillan” ian_macmillan@umail.ucsb.edu
Para: “Gruposig” gruposig@uniplac.net
Cópia: “GRASS mailing list” grasslist@baylor.edu
Assunto: Re: [GRASSLIST:4803]
Data: 12/11/04 11:08Set your region with
g.region vect=your_mapVisualize your map with
d.vect your_mapGood luck,
IanOn Nov 12, 2004, at 3:53 AM, Gruposig wrote:
Hello,
We have dificults to visualize the map. We import a .dxf file and
generate a
object map. And now, what steps do we have to follow to visualize the
map?grupoSIG-Uniplac,Lages-Brazil.
Message sent using UebiMiau 2.7.8
