[GRASSLIST:4826] Problems importing Data into lat/lon with negtiv south value
Dear Users,
I am trying to import some MODIS data into GRASS. In a first step I
managed to convert a subdataset of the MODIS data into img-format using
gdal_translate.
The dataset is a global dataset which should be in lat/long.
gdal_translate HDF4_SDS:EOS_GRID:"modis.hdf":2 -of HFA test_hdf.img
Input file size is 3600, 1800
0...10...20...30...40...50...60...70...80...90...100 - done.
steph@bim:~/modis > gdalinfo test_hdf.img
Driver: HFA/Erdas Imagine Images (.img)
Size is 3600, 1800
Coordinate System is `'
Origin = (0.000000,0.000000)
Pixel Size = (1.00000000,1.00000000)
Metadata:
  HDFEOSVersion=HDFEOS_V2.4
  LOCALGRANULEID=MOD08D3H.A2003090.004.2003093014745.hdf
  PRODUCTIONDATETIME=2003-04-03T01:47:45.000Z
  DAYNIGHTFLAG=Both
  REPROCESSINGACTUAL=processed once
  LOCALVERSIONID=004
  REPROCESSINGPLANNED=further update is anticipated
  VERSIONID=4
  SHORTNAME=MOD08D3H
  INPUTPOINTER=MOD04_L2.A2003090.0250.004.2003092034313.hdf,
[more metadata skipped]
EASTBOUNDINGCOORDINATE=180.000000
WESTBOUNDINGCOORDINATE=-180.000000 SOUTHBOUNDINGCOORDINATE=-90.000000
  NORTHBOUNDINGCOORDINATE=90.000000
  RANGEENDINGDATE=2003-04-01
  RANGEENDINGTIME=00:00:00
  RANGEBEGINNINGDATE=2003-03-31
  RANGEBEGINNINGTIME=00:00:00
  PGEVERSION=4.0.3
  ASSOCIATEDSENSORSHORTNAME=MODIS
  ASSOCIATEDPLATFORMSHORTNAME=Terra
  ASSOCIATEDINSTRUMENTSHORTNAME=MODIS
  PROCESSINGENVIRONMENT=Linux minion425 2.4.18-27.7.xsmp #1 SMP Fri Mar
14 05:52:30 EST 2003 i686 unknown
LOCALINPUTGRANULEID=MOD04_L2.A2003090.0250.004.2003092034313.hdf,
  LONGNAME=MODIS/Terra Aerosol Cloud Water Vapor Ozone Daily L3 Global
0.1 Deg CMG valid_range=0, 18000
  _FillValue=-9999
  long_name=Sensor Zenith Angle (Cell to Sensor): Mean
  units=Degrees
  scale_factor=0.01
  add_offset=0
  Level_2_Pixel_Values_Read_As=Real
  Derived_From_Level_2_Data_Set=Sensor_Zenith
  Included_Level_2_Nighttime_Data=False
  Quality_Assurance_Data_Set=None
  Statistic_Type=Simple
  Aggregation_Data_Set=None
Corner Coordinates:
Upper Left ( 0.0000000, 0.0000000)
Lower Left ( 0.000, 1800.000)
Upper Right ( 3600.000, 0.000)
Lower Right ( 3600.000, 1800.000)
Center ( 1800.000, 900.000)
Band 1 Block=64x64 Type=Int16, ColorInterp=Undefined
steph@bim:~/modis >
The problem seems to be with negative south and west values, as GRASS
needs south boundaries as 90S and not -90 (as my data have).
Is there a solution to use this kind of data in GRASS? Thanks for any
pointers on this topic.
Kind Regards
  Stephan Holl
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
On Sun, 14 Nov 2004, Stephan Holl wrote:
Dear Users,
gdal_translate.
What actually is the problem? Did something go wrong when you tried to import it into GRASS? Was this using r.in.gdal? And which GRASS version?
Paul
Hello Paul,
On Sun, 14 Nov 2004 11:55:34 +0000 (GMT) Paul Kelly
> Dear Users,
> using gdal_translate.
> GRASS needs south boundaries as 90S and not -90 (as my data have).
> any pointers on this topic.
version?
yes, r.in.gdal did not work, because latitude for south was illigal.
Proceeding with import...
WARNING: G_set_window(): Illegal latitude for South
no map is imported.
thanks for any hints.
Stephan
Stephan Holl
When I was trying to expand my r.in.aster script to include MODIS data, I
got a message from Frank Warmerdam (GDAL head developer) that there was a
problem in georeferencing MODIS with GDAL. If I remember, I think it had to
do with the MODIS metadata that gdalwarp would use for georeferencing.
Michael Barton
On 11/14/04 11:31 AM, "Stephan Holl" <sholl@gmx.net> wrote:
Hello Paul,
Dear Users,
version?
no map is imported.
Stephan
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
Hello Stefan
version?
no map is imported.
This doesn't really explain what looks like a bug, but I think it is a side-effect of GDAL trying to set the current region to match the imported data, which IMHO I don't think it should do. E.g. what if you were running an analysis in the background for which the region set was very important, and then imported a new file and r.in.gdal suddenly changed the current region?
I think it should only do this if the -e flag to extend the region is given, or perhaps there should be a new flag specifically to set the region to match the imported file.
If you comment out the lines in raster/r.in.gdal/main.c:
     if(G_set_window (&cellhd) < 0)
         exit(3);
and re-compile does it work?
Although seeing that doesn't fix the underlying bug, it might run into problems later I suppose.
Anybody else have an opinion on the region setting and extending behaviour of r.in.gdal and v.in.ogr?
Paul
>> version?
> no map is imported.
region?
r.in.gdal doesn't modify the WIND file. If you use the -e flag, it
modifies the DEFAULT_WIND file in the PERMANENT mapset[1], otherwise
it only modifies the process' internal region.
[1] At least, it tries to; obviously, if you don't have write
permission of the PERMANENT mapset, this will fail.
I'm not sure that there would be much point, as you can just use
"g.region rast=..." if you want that behaviour.
         exit(3);
If r.in.gdal is importing a georeferenced raster, it should attempt to
set the correct bounds and resolution (i.e. cellhd) for that raster,
rather than using (0,0,W,H). It shouldn't attempt to set the current
region or the default region; that should be left to g.region (which
should have an option to set the default region).
I don't think that this is an issue for v.in.ogr; AFAIK, vector maps
don't have a region (cellhd).
region?
I don't disagree that this is the actual behaviour, but on reading though the source code it seems to me this wasn't the intended behaviour and it is trying to write out the bounds of the imported map as the current region (i.e WIND). But G_set_window() doesn't change anything because of some caching it does or something (I looked into it a long time ago and don't remember all the details now).
Unless I'm misunderstanding what G_set_window() is supposed to do but I think it's for setting the current region.
Yes I agree, except from what I've noticed it seems r.in.gdal was designed to actually do this. But maybe these lines should really be deleted then:
         exit(3);
If you are using v.in.ogr to create a new location based on the projection
of the vector map being imported, it has to create a DEFAULT_WIND, and it is
good to populate it with meaningful region extents, which can be got through
some OGR function (get extents or something like that).
Paul
>> region?
G_set_window() sets the process' internal region (i.e. G__.window),
not the WIND file. It doesn't modify the WIND file, and isn't meant
to.
If you want to set the mapset's current region (i.e. the WIND file),
you need to use G_put_window(). If you want to modify some other file
(i.e. PERMANENT/DEFAULT_WIND or a cellhd file), you need to use
G__put_window().
Quite a few programs use G_set_window() to set a window other than
that defined in the WIND file.
E.g. programs which operate on the raw raster data without clipping,
padding or resampling (e.g. r.proj, r.bilinear) copy the raster's
cellhd to the current region:
  G_get_cellhd(mapname, mapset, &window);
  G_set_window(&window);
Similarly, import (r.in.*) programs set up a region with the same
number of rows and columns as the raster being imported. If
georeferencing information is available, they will set the boundaries
from that, otherwise they typically place the south-west corner at
(0,0) and the north-east corner at (W,H) (i.e. nsres == ewres == 1).
However, only those programs which wish to make persistent changes
(e.g. g.region, d.zoom) use G_put_window().
I'm fairly certain that r.in.gdal's behaviour (both with and without
the -e flag) is intentional.
>> exit(3);
No. Any raster import program has to at least set the window such that
the rows/cols values match the actual number of rows and columns.
Either that, or it will have to manually resample the image.
G_put_raster_row() etc don't do any resampling. They expect the buffer
to contain <cols> values, and they expect to be called exactly <rows>
times.
Most raster programs take their region (and hence grid dimensions)
from the WIND file, but import programs take the grid dimensions from
the file being imported, and so have to set the region to match.
Right; if you're creating a new location, it makes sense.
to.
G__put_window().
Right; get you there.
I wonder then why it doesn't just extend the current region, as (as I understand it) can be done reliably because the current user definitely has permission to change it, rather than extending the default.
I don't think the -e flag is working in v.in.ogr. If I get a chance sometime I will try and update it to extend the current region, or perhaps it could be removed as regions aren't so relevant for vectors (should they be?)
Paul
Yeah, I thought that too.
Maybe it's because you can extend the current region yourself with
"g.region rast=...", but g.region doesn't allow you to change the
default region (which is a pretty major deficiency, IMHO).
