[GRASSLIST:484] NVIZ error
Hello,
I tried to export a keyframe animation to an mpeg file but I got this error:
Error: gsd_init_mpeg failed to initialize MPEG stream
     while executing
"Ninit_mpeg $animBaseName"
     (procedure "animRunAndSave" line 36)
     invoked from within
"animRunAndSave .middle.panelarea.panels.animation"
     invoked from within
".middle.panelarea.panels.animation.bottom.rands invoke"
     ("uplevel" body line 1)
     invoked from within
"uplevel #0 [list $w invoke]"
     (procedure "tk::ButtonUp" line 22)
     invoked from within
"tk::ButtonUp .middle.panelarea.panels.animation.bottom.rands"
     (command bound to event)
Thanks for any help
Wolfgang
(PS when I'm not completely wrong, I'm running grass6.1.csv on cygwin)
     while executing
gsd_init_mpeg() should write its own error messages to stderr; check
the terminal window for one of the following:
  codec not found
  could not open codec
  Cannot open file for output
Hello,
I also found this message:
NVIZ has not been built with MPEG output support
so it's getting clear why it is not working ;-(( Is compiling NVIZ as difficult (for a beginner) as compiling Grass? What do I need do do? Or are there other ways to combine the rendered key frames to a movie?
Wolfgang
     while executing
  codec not found
NVIZ will be compiled along with the rest of GRASS if the relevant
options are enabled. However, NVIZ has the most dependencies of any
GRASS component, so compiling GRASS with NVIZ may be more work than
compiling without it.
You can output a series of images then generate a movie using a
stand-alone encoder such as ffmpeg.
Here the solution is to install FFMPEG :slight_smile: and to use
--with-ffmpeg --with-ffmpeg-includes=/usr/include/ffmpeg
(or something like that) in the ./configure stage during build.
Hamish
Does anybody know the exact syntax for
--with-ffmpeg-includes=/usr/include/ffmpeg, and which packages should be
included? In Debian testing I could not find an ffmpeg-dev package, and thus
I do not have /usr/include/ffmpeg.
Thanks.
pc
At 18:16, venerdì 31 marzo 2006, Hamish has probably written:
Hamish
Paolo Cavallini
email+jabber: cavallini@faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
I also never built Grass on my own! I just use the installer from cygwin, but this is a binary package. Building grass on cygwin seems for me even more complex than on a native linux system.
Wolfgang
PS. I have the same problem with building the new v.in.dxf. Probably I habe to wait for a binary release where these functions are included.
Paolo Cavallini schrieb:
Does anybody know the exact syntax for --with-ffmpeg-includes=/usr/include/ffmpeg, and which packages should be included? In Debian testing I could not find an ffmpeg-dev package, and thus I do not have /usr/include/ffmpeg.
Thanks.
pc
Hamish
thanks for clarifying this. do you remeber the name of the deb package
for ffmpeg? I found only ffmpeg (no -dev package, thus no /usr/include).
$ apt-file search /usr/include/ffmpeg/
#libavcodec-dev # for FFMPEG support
libavcodeccvs-dev# for FFMPEG support
libavutilcvs-dev # for FFMPEG support
Use Christian Marillat's non-free repo for the CVS version.
deb ftp://ftp.nerim.net/debian-marillat/ sarge main
Hamish
