[GRASSLIST:4850] Compilation of GRASS 5.7
Hello,
I just compiled and installed GRASS5.7. under cygwin.
My configure command: ./configure --with-postgres=no --with-odbc=no
When I start grass57 -tcltk I get the following error message:
Error in startup script: couldn't execute "ps.map": no such file or
directory
    while executing
"exec ps.map -p"
    (procedure "DmPrint::init" line 14)
    invoked from within
"DmPrint::init"
    (procedure "main" line 30)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-5.7.cvs/etc/dm/d.m.tcl" line 874)
After pressing ENTER I can start a monitor and open raster datasets but when
I try to display a vector file with d.vect I got:
"command not found"
Then I checked the error.log and found a whole bunch of errors (see below).
Can anybody help me with that?
Thank you for suggestions
Richard
error.log
GRASS GIS compilation log
Started compilation: Tue Nov 16 14:08:23 2004
Errors in:
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/lib/proj
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/lib/vector/Vlib
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/lib/sites
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/lib/rst/interp_float
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/lib/ogsf
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/db/drivers/ogr
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/display/d.path
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/display/d.vect
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/display/d.vect.chart
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/display/d.what.vect
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/display/d.where
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/display/d.zoom
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/general/g.proj
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/general/g.region/cmd
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/general/g3.region
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/general/g.setproj
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/general/manage/cmd
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/imagery/i.vpoints
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/ps/ps.map
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.contour
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.cost
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.flow
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.le/r.le.setup
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.proj
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.random
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.region
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.resamp.rst
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.sun
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.sunmask
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.to.vect
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.in.gdal
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster3d/r3.showdspf
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.buffer
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.build
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.build.polylines
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.category
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.clean
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.convert
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.database
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.db.connect
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.digit
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.distance
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.extract
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.hull
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.info
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.in.ascii
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.in.db
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.in.region
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.in.sites
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.kcv
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.kernel
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.label
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.proj
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.mkgrid
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.neighbors
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.net
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.net.alloc
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.net.iso
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.net.path
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.net.salesman
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.net.steiner
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.normal
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.out.ascii
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.out.dxf
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.out.pov
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.overlay
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.patch
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.perturb
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.qcount
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.random
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.reclass
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.sample
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.segment
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.select
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.surf.idw
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.surf.rst
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.transform
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.to.db
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.to.points
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.to.rast
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.type
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.univar
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.voronoi
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.what.rast
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.vol.rst
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.out.ogr
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.in.ogr
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.external
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/visualization/nviz
Finished compilation: Tue Nov 16 14:45:00 2004
Errors in:
Both of these errors are critical, in that they will result in many
necessary programs failing to compile.
You need to examine the output from "make" to determine why the
compilation failed.
