[GRASSLIST:4904] Re: v.proj question
On Thu, Oct 31, 2002 at 10:52:57AM +0100, michele.rocc@libero.it wrote:
I neeed to perform a conversion of a isolines vector map, not really
a datum conversion but a "fuse conversion" because two adiacent maps
has coordinates referred to two different fuses.
Is v.proj useful to do this or is it still limited to nad27 - nad83
conversion as specified in the man page?
In this case is there another way to perform this tipe of conversion
(for examp. reproject UTM(WGS84) Fuse 33N vector map to UTM(WGS84) Fuse
32N)?
You are right: Italian fuse conversion is no datum transformation
(AFAIK). So v.proj will work fine for that.
