Hi there,
Just digitized on screen a bunch of areas with v.digit and would like to convert those
polygons into a raster map.
v.to.rast did the trick of digitizing the borders of the polygon. But how do I get it to
rasterize the inside too? I'd like to use those polygons as mask before running
r.describe on some raster coverage. Am I missing something?
Thanks for your help
Thomas
Thomas Dewez
PhD Student
Dept Geography & Earth Sciences
Brunel University (West London)
Uxbridge UB8 3PH, Mddx
United Kingdom
Phone: +44-(0)1895-203215
Fax: +44-(0)1895-203217
e-mail: thomas.dewez@brunel.ac.uk
Hi Malte,
is it a silly question to ask how the best ascii input for r.in.poly would
be generated? My attempt with v.out.ascii doesn't seem to work.
Where on earth is the output of v.out.ascii sent to?
Thomas
Hi Thomas,
r.in.poly?
Malte
Thomas Dewez schrieb:
>Hi there,
>to convert those polygons into a raster map.
>how do I get it to rasterize the inside too? I'd like to use those
>polygons as mask before running r.describe on some raster coverage.
>Thomas
>Thomas Dewez
>PhD Student
>United Kingdom
Thomas Dewez
PhD Student
United Kingdom
I am pretty sure that the output of v.out.ascii goes to the
(newly created if it did not previously exist) dig_ascii
subdirectory in the current mapset.
Best regards,
Michael
Michael Ash, Assistant Professor
of Economics and Public Policy
Department of Economics and CPPA
University of Massachusetts
Amherst, MA 01003
Tel 413-545-6329 Fax 413-545-2921
Email mash@econs.umass.edu
http://www-unix.oit.umass.edu/~maash
On Thu, 14 Nov 2002, Thomas Dewez wrote:
Hi Malte,
Thomas
> Hi Thomas,
> r.in.poly?
> Malte
> >Hi there,
> >Thomas
> >Thomas Dewez
> >PhD Student
> >United Kingdom
Thomas Dewez
PhD Student
United Kingdom
On Thu, Nov 14, 2002 at 12:46:23PM -0000, Thomas Dewez wrote:
Hi there,
polygons as mask before running r.describe on some raster coverage. Am
Are the vector polygons built as areas?
static const char signature =
"Copyright (c) 2002 Eric G. Miller <egm2@jps.net>";
Hi Eric and others,
I repeated the v.to.rast operation with the same parameters and this
time I obtained a raster coverage of solid polygons. Not sure what
happened, the history log doesn't show that I did anything different
than the first time... Mystery, but it worked!
Thanks to all for your help
Thomas
> Hi there,
> like to convert those polygons into a raster map.
> But how do I get it to rasterize the inside too? I'd like to use
> those polygons as mask before running r.describe on some raster
Thomas Dewez
PhD Student
United Kingdom
