[GRASSLIST:4957] RE: r.le.pixel null() problem
hi Bill,
I did the whole process again with different setups:
the r.le.setup is for moving window, enter radius with keyboard, circle ("1.5" up to "8.5" in 1 steps) or square ("2 2" up to "15 15" in 1 steps), default for all other options.
map n_02l is set to null for all values inside a firescar
r.le.pixel map=n_02l sam=m att=b1 (i did it with some div and te1+2 as well, but didn't bother to do it for the different setup tests)
output circles: 1.5 inside firescar is "0", 2.5 up to 8.5 is "null"
outout squares: 2 2 up to 15 15 inside firescar is 0 but the area is getting smaller with increasing radius. the edges are null.
I checked the pixelvalues inside the firescar in image n_02l, they are null.
hope that helps, thanks Martin
15/11/2002 2:07:15 AM, "William L. Baker" <BakerWL@uwyo.edu> wrote:
Hi Martin,
I need a little more information to be able to understand
the bug. I'm the author of r.le programs.
Are you using circles or squares in r.le.setup? Can you send
the exact syntax of the r.le.pixel command that produced a
"0" with 1.5 radius and null with larger radii?
Thanks.
Bill Baker
-----Original Message-----
Sent: Wednesday, November 13, 2002 8:40 PM
To: GRASSLIST
Subject: [GRASSLIST:4944] r.le.pixel null() problem
hello,
it's rather a remark than a question.
I set all my firescarsvalues on my satellite image to "null()" (r.mapcalc map_out=if(map_in<=x,null(),map_in) )and
calcualted mean, sd, diversity etc. with r.le.pixel. When I choose 1.5 pixel radius in the r.le.setup the output inside the
firescars which I set to null, were "0". All the calcualtion with radius 2.5, 3.5, 4.5 and 8.5 were "null()" as expected.
perhaps I am wrong but it looks like a bug .... or a stupid user :wink:
cheers Martin
Martin Wegmann
Tropical Ecosystem Research Center
PMB 44 Winnellie / Darwin
NT 0821
Australia
priv.
4 Carpentier Cres.
Wagaman / Darwin
NT 0810
Autralia
0061 8 8927 1241
Martin Wegmann
NT 0821
Australia
priv.
4 Carpentier Cres.
Wagaman / Darwin
NT 0810
Autralia
0061 8 8927 1241
