hi to all...
do someone know the .mxt extension what is about???
they gave me some files in this format and I don't know what I have to
do with them....!!!!
thanks!!!
ivan marchesini <marchesini@unipg.it>
hi to all...
thanks!!!
maybe it is ESRI arcmap template file format,
some kind of map template documents like MS-WORD templates.
mxt files are used as a template to create map documents in arcmap (files of type .mxd)
ArcMap replace the old .prj files used to create maps in Arcview...
Anyway as far as i know you need Arcmap to process these files.
Michail
ivan marchesini wrote:
hi to all...
thanks!!!
* Παντελέλης Μιχαήλ | Michail G. Pantelelis *
* Πανεπιστήμιο Αιγαίου | University of the Aegean *
* Επιτροπή Ερευνών | Research Unit *
* Λόφος Πανεπιστημίου | University Hill *
* Μυτιλήνη 81100 | Mytilene 81100 *
* Ηλ.Ταχ. mpantel@aegean.gr e-mail *
* Τηλ. +30(22510)36713 Phone *
-----BEGIN PGP PUBLIC KEY BLOCK-----
Version: GnuPG v1.2.4 (GNU/Linux)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=P4VA
-----END PGP PUBLIC KEY BLOCK-----
>hi to all...
An .mxt file is an ESRI ArcGIS template file, it works like a M$ Word ".dot"
file.
Usually, the .mxt file itself is _useless_ since it is used (when it works) to
define a base layout (e.g. paper size, map frame position, legend position,
presentation coverages and so on) for bulk map procuction in series.
Of course, the .mxt, once opened, will generate a new document, and probably
it will serach for some shapefile or coverage or grid or imagery...
HTH!
Damiano G. Preatoni, PhD
Unità di Analisi e Gestione delle Risorse Ambientali
Dipartimento "Ambiente-Salute-Sicurezza"
Università degli Studi dell'Insubria
Via J.H. Dunant, 3 - 21100 Varese (ITALY)
http://biocenosi.dipbsf.uninsubria.it/
ICQ: 78690321
Odigo: 2645129
