With your permission, I am posting my response to
grasslist@baylor.edu which, I learned recently, is more
focused on _users'_ questions and discussion than is the
development-oriented grass5@grass.itc.it. (See
http://grass.itc.it/support.html#int_list for details on how
to join) I hope that you do not consider the shift of venue
rude.
I too have had difficulties importing shapefiles with
v.in.shape. I have had more success importing the same set
of vectors from .e00 files, the ESRI export format with
m.in.e00. Perhaps your shapefile source can also provide
.e00 versions.
Best regards,
Michael Ash
3. Problem with shapefile (Virgilio =?ISO-8859-1?Q?G=F3mez?= Rubio)
7. Re: Problem with shapefile (David D Gray)
Message: 3
From: Virgilio =?ISO-8859-1?Q?G=F3mez?= Rubio <Virgilio.Gomez@uv.es>
To: grass5@grass.itc.it
Date: 15 Nov 2002 14:56:00 +0100
Subject: [GRASS5] Problem with shapefileHi all,
It's been a long time since we met in Trento, isn't it?
I am writting because I have a problem when timporting a shapefile.
What happens is that some lines (and ares) are lost. The command line
and error message I get are:GRASS:~/tmp > v.support option=build -r map=cod_munici
err=err_cod_municiV.SUPPORT:
Selected information from vector header
Organization:
Map Name: cod_munici
Source Date:
Orig. Scale: 2400
Snapping threshold 0.00
Snapp No snapping will be done
Reading Vector file 100%
Building areas 100%
Unclosed area, free end or edge inside area: line 771
Unclosed area, free end or edge inside area: line 773
Unclosed area, free end or edge inside area: line 777
Unclosed area, free end or edge inside area: line 828
Unclosed area, free end or edge inside area: line 829
Unclosed area, free end or edge inside area: line 1774
Unclosed area, free end or edge inside area: line 1776
Building islands 100%
Attaching labels
PNT_TO_AREA failed: (765673.634168, 4491702.952495) (Category 12052)
PNT_TO_AREA failed: (768903.289024, 4484561.074964) (Category 12100)
PNT_TO_AREA failed: (718003.592441, 4386435.398790) (Category 46070)
PNT_TO_AREA failed: (712646.684383, 4382275.341311) (Category 46116)
WARNING: area 176 label: 46902 matched another label: 12066.
PNT_TO_AREA failed: (714668.427559, 4382979.700161) (Category 46903)
PNT_TO_AREA failed: (717899.462949, 4378108.989802) (Category 46190)
Number of lines: 1876
Number of nodes: 1244
Number of areas: 651
Number of isles: 28
Number of atts : 652
Number of unattached atts : 6
Snapped lines : 0I think the problem is related to that unclosed areas, but it is also
true that ArcVIew reads the shapefile without problems.Any idea?
Of course, if some developer wants to try the shapefile I can send it to
him/her.Regards, thanks and best wishes,
Virgilio Gómez RubioDpto. Estadística e I. O. - Facultat de Matemàtiques
Avda. Vicent A. Estellés, 1 - 46100 Burjassot
Valencia - SPAINTLF: 00 34 96 386 43 62 - FAX: 00 34 96 398 35 99
--__--__--
Message: 7
Date: Sat, 16 Nov 2002 03:19:02 +0000
To: =?ISO-8859-1?Q?Virgilio_G=F3mez_Rubio?= <Virgilio.Gomez@uv.es>
CC: grass5 developers list <grass5@grass.itc.it>
Subject: Re: [GRASS5] Problem with shapefileVirgilio Gómez Rubio wrote:
> Hi all,
> err=err_cod_munici
> V.SUPPORT:
> Organization:
> Source Date:
> Orig. Scale: 2400
> Building areas 100%
> Attaching labels
> Number of isles: 28
> Snapped lines : 0
>Hi,
The most likely reason is that the areas do not build because there are
'topologically incorrect' features in the affected polygons - for
example, one polygon edge has a vertex where its neighbour has none, for
example, as follows:-------------A----------------B-------------------------C-----
-------------A------------------------------------------C-----The stable release of the import process recognises the loop A-B-C-A as
a 'degenerate' polygon, but the build process detects it as an error, so
the the areas adjacent to the affected segment do not build.>
>It may appear that ArcView has no problems but its display does not
check to see if polygons are correctly matched with their neighbours.
This can affect various processing algorithms (ie ArcScripts) as well as
the attribute table. For example the degenerate polygons may or may not
be listed in the DBF file. (What you expect of course is that they
shoudn't be)> Any idea?
>The best procedure is to track down the problem polygons with v.digit
and eliminate the offending lines.0) Back up the attributes file in dig_att under the mapset. This is just
cd'ing to the dig_att directory and copying the file to something
convenient.
1) Use Tools | o to highlight the problem areas.
2) The option Tools|n will help to track down which of the polygons
edges are problems. v.rm.dangles might help also.
3) When you are confident a particular line is a duplicate or otherwise
problem edge, you can go back to the top level and use Edit|r to remove it.
4) When the bad edges have been fixed, go back to the dig_att directory,
resotore the atts file to the correct name and then rebuild.> Of course, if some developer wants to try the shapefile I can send it to
> him/her.
>In a former version v.in.shape went to considerable lengths to try and
elliminate many errors automatically, but this ended up introducing far
more problems than it solved. The current version is at the other
extreme - it import maps as they are, and if there are problems they
must be fixed manually. A revision of the module is in progress that
will remove errors only of the kind described above. In usable maps 99%
of errors are caused this way anyway. If there are more serious errors,
the map is pretty corrupt anyway, and maybe then you should request the
source to provide a better set of files.David
