Hello all,
is it possible to create anaglyph images (to view with red-and-blue 3D glasses)
with GRASS?
thanks all
Carlos Grohmann
Carlos Henrique Grohmann - Guano
Geologist M.Sc - PhD Student at IGc-USP - Brazil
Linux User #89721 - guano at usp dot br -
On Mon, Nov 29, 2004 at 03:01:27PM -0200, Carlos Henrique Grohmann wrote:
Hello all,
with GRASS?
yes, it's possible:
I was playing with that some time ago (using GRASS):
http://www.geog.uni-hannover.de/users/neteler/stereo/welcome.html
The procedure is roughly described.
Best
Thanks for your answer, Markus, but I still have some doubts: the procedure you
describe is for aerial photos, but I want to do it with DEMs. So, which points
shuld I use in d.fix.ortho, since there are no fiducial marks, and I only have
one image of the area?
thanks again
Citando Markus Neteler <neteler@itc.it>:
> Hello all,
glasses)
> with GRASS?
yes, it's possible:
Best
I didn't realize that you want to use a DEM.
Right, you will have to generate parallax which depends on
the local elevation height.
Once I tried to write some code, but never finished it.
It might be possible even with r.mapcalc.
