[GRASSLIST:4997] HELP: icon problem in ps.map
Hi, grassusers,
I am using Grass 5.0.0 to work for my project. Now I am facing a weird
problem. Here it is: I created some icons using ps.icon. In my project, I
used point instruction with different icons to denote the countys crop.
Since I have 89 counties, the multiple point instructions are needed; and
an icon might be used continuously. The problem is that if an icon is used
continuously, it can ONLY be displayed in the FIRST point; the other
continuous points will be showed as diamonds (For example, the Roma4 icon
in my sample codes only point (170238.75 2078816.42) shows as Roma4). But
if an icon is not used continuously, it always shows fine. Anybody can
help me out? It is so weird
John
point -637698.75 2086607.42
    icon Roma1
    color blue
    size 1.2
    masked n
end
point -324111.00 2109980.42
    icon Roma4
    color magenta
    size 1.2
    masked n
end
point -170238.75 2078816.42
    icon Roma4
    color magenta
    size 1.2
    masked n
end
point -581214.00 2156726.42
    icon Roma3
    color aqua
size 1.2
    masked n
end
On Tuesday 19 November 2002 06:34 pm, Zhong Xu wrote:
Hi, grassusers,
I don't have explanation for this, I want only note that
if you have 89 points, it may be better to print them as sites.
If you create site file mysites:
-637698.75|2086607.42|#1
-324111.00|2109980.42|#4
-170238.75|2078816.42|#4
-581214.00|2156726.42|#3
and EPS files Roma1.eps, Roma3.eps, Roma4.eps you can print with ps.map:
sites mysites
  eps Roma$.eps
end
Radim
