Hi everyone,
I just noticed that I can no longer connect to my MySQL tables from within
GRASS 5.7-cvs..
before I could execute:
db.connect driver=mysql
database="host=localhost,dbname=test,user=xxxx,password=xxxx"
and i could then work with tables in MySQL...
now, even after setting the connection parameters with db.connect, i get the
following errors when executing `db.tables -p`:
-------------error messages-------------
db.tables -p
WARNING: 'user' in database definition is not supported, use db.connect
WARNING: 'password' in database definition is not supported, use db.connect
DBMI-MYSQL driver error: mysql_real_connect() error (1045): Access denied for
user: 'dylan@localhost' (Using password: NO)
and the following shows up in mysql.log
----------mysql.log------------
Access denied for user: 'dylan@localhost' (Using password: NO)
...somehow GRASS 5.7-cvs from last month was able to connect to mysql, but the
latest one is having problems passing some parameters (username and password)
to mysql
any ideas?
thanks in advance
Dylan Beaudette
Soil Science Graduate Group
University of California at Davis
