[GRASSLIST:5028] r.plane problem
Dear users...
I'm trying to use r.plane within grass57...
the region settings are:
__________________________
zone: 0
datum: rome40
ellipsoid: international
north: 4745617.74
south: 4743280.26
west: 2350445.5
east: 2355261.01
nsres: 1.72
ewres: 1.61
rows: 1359
cols: 2991
___________________________
I use this command:
______________________________________________________________
r.plane dip=30 az=100 ea=2355000 no=4745000 el=100 name=plane
and I obtain:
____________________________________________________________________
/usr/local/grass-5.7.cvs/scripts/r.plane: line 112: test: 2355261.01:
integer expression expected
Sorry, point must be within current region
Current region:
west: 2350445.5 east: 2355261.01
_____________________________________________________________________
do you know which is the problem???
thank you
Ivan
ivan marchesini <marchesini@unipg.it>
On Thu, Dec 02, 2004 at 06:35:37PM +0100, ivan marchesini wrote:
Dear users...
zone: 0
datum: rome40
north: 4745617.74
south: 4743280.26
west: 2350445.5
east: 2355261.01
nsres: 1.72
ewres: 1.61
rows: 1359
cols: 2991
I use this command:
and I obtain:
Current region:
thank you
I tried with Gauss-Boaga Fuso Ovest,
works fine.
To debug this shell script, simply edit
and add -x to the top line:
#!/bin/sh -x
Then re-run and it will display all steps. From that you
may understand what's wrong (and report or send the fix).
Thanks
Thank you Markus....
I have seen that the problem was the region...
because I had float value and the script needs integer.....
simply changing float value to integer all is correctly working!!!!!
thank you
> Dear users...
> zone: 0
> datum: rome40
> north: 4745617.74
> south: 4743280.26
> west: 2350445.5
> east: 2355261.01
> nsres: 1.72
> ewres: 1.61
> rows: 1359
> cols: 2991
> I use this command:
> and I obtain:
> Current region:
> thank you
works fine.
#!/bin/sh -x
Thanks
The script also works with floating point coordinates (for me).
Please report the detailed log of sh -x.
thank you
> > Dear users...
> > zone: 0
> > datum: rome40
> > north: 4745617.74
> > south: 4743280.26
> > west: 2350445.5
> > east: 2355261.01
> > nsres: 1.72
> > ewres: 1.61
> > rows: 1359
> > cols: 2991
> > I use this command:
> > and I obtain:
> > Current region:
> > thank you
> works fine.
> #!/bin/sh -x
> Thanks
> Markus
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
