-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
After the new command db.login and the remotion of v.database I have some
problem with the relocation of the table when I import vectors (like shapes)
in GRASS.
Grass put the table in the database setted in the options GV_* of file VAR
placed in the working mapset.
I see that the command db.connect change the DB_* options but not the GV_*
options.
How can I change the GV_* options and what about the function of the DB_*
options?
Thanks of all
Leonardo
About overwrite protection I think that it is very important to have a flag
to avoid delete the tables linked to a vector when I delete the vector. What
do you think about it?
Bye
Leonardo
- - -- Personally I like overwrite protection & to have to specifically use
> > the -o flag.
> For vectors you can use
> g.gisenv set=OVERWRITE=0
> Radim
Leonardo Lami
lami@faunalia.it www.faunalia.it
Via Colombo 3 - 51010 Massa e Cozzile (PT), Italy Tel: (+39)349-1310164
GPG key @: hkp://wwwkeys.pgp.net http://www.pgp.net/wwwkeys.html
https://www.biglumber.com
- -----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFBruu+92hCyP73w7ARAlugAJ9LUJ5LL3zxvokwq743lHvIIx+k4ACfaRfI
q5qJVvaDvhura0QS0CWwviY=
=kxoh
- -----END PGP SIGNATURE-----
Leonardo Lami
iD8DBQFBsDSg92hCyP73w7ARAv2DAKCTCZ/CIc5uf0hXDf8X9XPsvWGzlQCgmquX
yiRbZuaLhRCl1kF6v7M4H94=
=xqpC
