-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Sorry but I retried it and the result is the some.
My VAR file is:
DB_DRIVER: dbf
DB_DATABASE: /home/Documenti/datigrass/Toscana/leo/dbf
GV_DRIVER: pg
GV_DATABASE: host=192.168.0.10,dbname=faunalia
GV_SCHEMA: prova
When I use v.in.ogr the table is stored in database faunalia schema prova.
If I change the VAR file in this way:
DB_DRIVER: dbf
...without GV_* options...
v.in.ogr say:
WARNING: Default driver / database for vectors set to:
driver: dbf
database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
and it put the tables in the dbf directory placed in the working mapset.
I can not understand it.
Bye
Leonardo
Alle 12:01, venerdì 03 dicembre 2004, hai scritto:
> Hash: SHA1
> Hi,
> After the new command db.login and the remotion of v.database I have some
> problem with the relocation of the table when I import vectors (like
> shapes) in GRASS.
> Grass put the table in the database setted in the options GV_* of file
> VAR placed in the working mapset.
> I see that the command db.connect change the DB_* options but not the
> GV_* options.
> How can I change the GV_* options and what about the function of the DB_*
> options?
> Thanks of all
> LeonardoGV_* are not used, vector tables are stored in database defined by DB_*
(db.connect).> About overwrite protection I think that it is very important to have a
> flag to avoid delete the tables linked to a vector when I delete the
> vector. What do you think about it?Almost impossible to add this flag to all modules. Why do you need that?
Cannot you db.copy the table?Radim
Leonardo Lami
lami@faunalia.it www.faunalia.it
Via Colombo 3 - 51010 Massa e Cozzile (PT), Italy Tel: (+39)349-1310164
GPG key @: hkp://wwwkeys.pgp.net http://www.pgp.net/wwwkeys.html
https://www.biglumber.com
- -----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFBsFhh92hCyP73w7ARAgS0AJ9n/aSMYdmuRfQatEyaJ9CM4oemBwCfbXOp
G91Ws+RPXlf57nsD1IKQR7Q=
=WuVu
- -----END PGP SIGNATURE-----
Leonardo Lami
iD8DBQFBsGfu92hCyP73w7ARAiLBAKCjD5F1weoFfM5CBiSVD4gnOn66FgCdHRhk
/UFiieeF1PqcC4v8nJezUow=
=aAgU
