Hi all;
Is there any command to export a image from what I have in my display monitor?
It is a stack of raster, overlayed by sites and vect maps.
Javier
Hi all;
Javier
You can use the PNG driver ("d.mon start=PNG") to direct the output of
d.* commands into a PNG image.
You can use d.save to obtain a script of the commands which were used
to generate the display on the current monitor.
