[GRASSLIST:5065] width of geogrid lines in ps.map
Grass folk,
Is is possible to control the width of the lines that the geogrid function draws when using ps.map? I am converting the ps.map generated postscript file to pdf via ps2pdf and then printing. The printed geogrid lines are extremely thin and hardly noticeable.
Thank you in advance,
Brent
RedHat FC2
Grass 5.7
DeskJet 810C
I don't think you can do it straight from ps.map, but you could make your own grid of vectors, then display that as lines and control their width. There used to be a v.mkgrid function, I am not sure if it is still around anymore.
G'luck
-Ian
On Dec 6, 2004, at 3:34 PM, Brent Crittenden wrote:
Grass folk,
Brent
RedHat FC2
Grass 5.7
DeskJet 810C
Ian,
Thanks for reply, and I apologize for the double post. Newbie.
I did not find the v.mkgrid function. I am deciphering the v.in.ascii command now to try to make grid of vectors.
Brent
It is in GRASS 5.0-5.4 but not 5.7.
It could be run in 5.4 and the results exported into 5.7..
Attempts to adapt the script to work with 5.7 are welcome.
Hamish
V.mkgrid is in the current cvs version of GRASS 5.7
Michael
PS: I'd also love to have a line width control in d.vect. V.buffer is a work
around that I'll have to remember.
On 12/6/04 9:48 PM, "Brent Crittenden" <brent.crittenden@hasletwireless.net>
wrote:
Ian,
Brent
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
