I just regridded (s.vol.v5d) with a grid using equal number of row and columns (but not depths). Now it works, although I'm still checking to see if its mirrored or otherwise messed up. I usually assume that my code (s.in.ubcgif in this case) is causing the problems. But then showdspf should not be working.
John Harrop
Note: The number 1 reason r3 code is not compiled by default has to do
with a discrepancy in row/col handling between regular rasters and
grid3d rasters. Nobody has stepped forward to fix the problem...
"...the plural of anecdote is [not?] data." - attrib. to George Stigler
John Harrop
Hi John,
the CVS code of GRASS 5.0.1 (to be released hopefully soon) contains
some fixes for the G3D from Alfonso Vitti (Univ. Trento) which
overcome a set of problems. AFAIK there is still a problem with
rows and cols not equal.
If you are able to compile GRASS 5.0.0, you may try the CVS version
or CVS snapshot. We definitly need 1 or 2 people to look again into
G3D and test the modules.
Best regards
Markus Neteler
