[GRASSLIST:5083] Re: surface roughness scale and colortable
1 - a few days ago, I posted a question about how to calculate the
surface roughness of an area. After a little brainstorm I did it. thanks
to all who answer, special to Thorsten Behrens and Eric Miller.
May I ask what worked?
Now I have a new problem with my recently-created roughness map: When I compare it with other similar map made with Arcview, I see that there's
a little difference in the scale of the roughness. In the arcview's map,
the scale goes from 1 (planar area) to 1.23, but in the GRASS's map, it goes
from 0 (planar area) to 67. I guess I have o normalise the values, but I
don't know how. Any ideas?
If you want 67 to be 1.23, and 0 to be 1, try something like:
r.mapcalc newmap='1+(oldmap*(0.23/67))'
2 - About the colortables (i guess this one is easy...): how can I set
my own colortable? I mean, it's not about changing the colortable using
the predefined ones (rainbow, red thru yellow, etc)?
have a look at the files in $mapset/colr after setting different colors=, and read the r.colors man page. I found it easiest to edit those files by hand.
> goes from 0 (planar area) to 67. I guess I have o normalise the values,
> but I don't know how. Any ideas?
Another approach is
r.rescale input=my_oldmap from=0,67 output=my_newmap to=1,1.23
(In fact, I would guess that r.rescale does not work with
decimal values. r.rescale appears intended to generate
integer color scales, e.g., 0 to 255; so the r.mapcalc
approach would be appropriate for this example, but you
might want to know about r.rescale for future use.)
Best,
Michael
