[GRASSLIST:5086] nviz segmentation fault
hello List,
I have a Problem with nviz (grass5.7.cvs-i686-pc-linux-gnu-27_11_2004 on
Suse Linux 9.1). When I will start nviz, only the message "segmentation
fault" appears, nothing else. Can someone help me, please?
Michael Holzmann
____________________________________________
Dipl.-Ing. Michael Holzmann
iaks GmbH
Hindelangerstr. 35
87527 Sonthofen
Tel. (08321) 78085-13
Fax (08321) 78085-99
On Wed, Dec 08, 2004 at 04:00:29PM +0100, Michael Holzmann wrote:
hello List,
I have manually launched the job to rebuild the Linux binary CVS snapshot:
http://grass.itc.it/grass57/binary/linux/snapshot/
We have applied a lot of stability fixed the last days, maybe
it already helps. If possible, please update to this snapshot
and report again if it works or not.
Additionally I have launched job to create the 5.7 source code CVS snapshot:
http://www.grass.itc.it/grass57/source/snapshot/
Thanks
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
