[GRASSLIST:5090] monitor export
Hello,
Is there a way I can export the contents of my monitor (raster, vectors) to
eps, tiff or something else?
Or better, is there a good map creating tutorial somewhere?
tks
   Carlos Henrique Grohmann de Carvalho - Guano
       Geologist - MSc Student IGc-USP
   Linux User #89721 PGP key: www.keyserver.net
Hello Carlos,
You can do it. The information is here:
http://grass.itc.it/gdp/html_grass5/html/pngdriver.html
Start up the driver
         d.mon start=PNG
         d.mon select=PNG
Display raster map and vector polygons
         d.rast somerastermap
         d.vect map=somevectormap color=red
Stop the driver subsequently. This will write a file named map.png to be
created in your current directory:
         d.mon stop=PNG
NOTES
----- Original Message -----
From: "Carlos Henrique Grohmann de Carvalho" <guano@usp.br>
To: <GRASSLIST@baylor.edu>
Sent: Wednesday, November 27, 2002 6:40 AM
Subject: [GRASSLIST:5090] monitor export
Hello,
to
tks
The PNG driver allows you to direct the output of d.* commands into a
PNG image. However, you need GD 2.x to get a 24-bpp image; GD 1.x only
supports 8-bpp (256 colour) images.
Or you can use the screen grab feature of an image program such as
ImageMagick to grab the contents of a window (the resulting image will
have the same colour depth as the screen).
For generating PostScript, you can use ps.map. This is probably less
flexible than using d.* commands, but will result in better quality
for vectors and text.
