[GRASSLIST:510] importing .E00 files
Hello,
I have been attempting to import .e00 files with
limited success. After I decompressing the files I
ran m.in.e00 -s [filename]. This generated several
other files in the dig_cats file under my mapset.
After copying all of these files g.copy
vect=[filename],[filename.something] I ran the d.vect
filename and there was nothing..no errors are given.
I went back and ran the v.info [filename] and the only
problem appears to be in the category field, there is
a question mark and not a numerical value. This I
suspect is the problem, but I do not know where to
look to fix the error.
Thank you for any help,
Stef
__________________________________
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
stef said:
Hello,
You mean the "Number of Categories:" field ? This just takes the highest
category number available, so it doesn't mean much if the category numbers
don't start with 1 and iterate with step 1.
This I
First of all, are you sure the region is set correctly ? Try g.region
vect=YourVectorMap, d.erase, d.vect YourVectorMap.
Moritz
