is there a way to place scale in NVIZ monitor such as with d.scale?
In theory:
Create a vector file in whatever way you like. I find making a grass ascii-vector file pretty easy. (see below, first line will be 5km long..) use v.in.ascii to convert that into a regular grass binary vector file & run v.support. use d.where to figure out where you want the starting coordinates to be, then just type in the numbers (adding 5000 to some) to make the 3 or 5 lines requried to make a nice "I" shape. Making "1KM" might not be too hard either. Might need v.digit to clean up nodes, etc.
Would it be possible to project something like PostScript with huge page dimensions to a vector file / write something to export PostScript to a grass ascii-vector file ???
So once you've got vector graphics of what you want to display, say a 5km long line start up NVIZ with your map, open the surfaces panel, New, New Constant, some evelation for the line to 'float' at, accept, transparency, new constant, 255, accept; then, Vector panel, new, load your vector file, accept, and click the check boxes so it displays only on the transparent surface. And there you go!
If you have a Lat/Lon region, you have to do some more math to figure out the positions, of course, but no trig as long as your scale bar runs N/S or E/W.
Could work.
