[GRASSLIST:5112] r.in.srtm
Hello again,
I'm having a problem using r.in.srtm. In response to the command r.in.srtm.sh I get:
/usr/local/bin/r.in.srtm.sh: line 1: {rtf1macansicpg10000cocoarttf102: command not found
/usr/local/bin/r.in.srtm.sh: line 2: syntax error near unexpected token `}'
/usr/local/bin/r.in.srtm.sh: line 2: `{\fonttbl\f0\fswiss\fcharset77 Helvetica;}'
Does anybody have experience of this? What's the problem?
Lawrence
doesn't look like a shell script - more like rtf. Are you sure you saved your script as plain text? Coming from the Mac OS X side, I can say that if you use TextEdit, the default format is rtf.
Better yet - the current 5.7 cvs has a cleaned up r.in.srtm included.
On Dec 10, 2004, at 5:01 AM, lawrence moran wrote:
Hello again,
Lawrence
William Kyngesburye <kyngchaos@charter.net>
http://webpages.charter.net/kyngchaos/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
